Thread: Novak M2 Dig with 23T 550 motors.......?
Old 02-25-2012, 09:20 AM   #1
Default Novak M2 Dig with 23T 550 motors.......?
Is anyone running Traxxas 23t 550 motors with the M2 Dig? I want to put my XR-10 back together and the only matching motors I have are the 23t from an E-maxx.
Thanks
BladeMech is offline   Reply With Quote
Old 02-25-2012, 11:45 PM   #2
Default Re: Novak M2 Dig with 23T 550 motors.......?
ummmmmmm is it the titan 12 turn 550? or a stinger 20 540? i don't think they make a 550 23 turn..
roninwarrior555 is offline   Reply With Quote
Old 02-26-2012, 01:43 AM   #3
Actually read posts much? They also used the same motors in the first of the e-revos as well IIRC.
Blademech: I think that would be pushing the limit of the M2. Reliability of them is spotty at the best of times, running a pair of hot(ish) motors might push them too far. Novak gives a motor limit of 27t single motor or dual 33t in 540 size.
WIDELOAD is offline   Reply With Quote
Old 02-26-2012, 06:40 AM   #4
Thanks WIDELOAD, your right I am just trying to be cheap and not buy the right motors.
Old 02-29-2012, 03:42 PM   #5
are you going to run 3s the motor limit for moa is 33t for 3s and 2s it 27t you cant go lower then that for moa on the novak m2 dig
honcho boy is offline   Reply With Quote
Old 03-01-2012, 09:29 AM   #6
For factory assistance with your question, you could email our tech guy, Charlie, suangka@teamnovak.com
NovakTwo is offline   Reply With Quote
Old 03-01-2012, 07:06 PM   #7
Will a 550 sized motor fit into a XR and not cause clearance issues with the bottom links?
Greatscott is offline   Reply With Quote
Old 03-01-2012, 09:16 PM   #8
you might have to make you own to fit but you can try
Old 03-02-2012, 09:47 AM   #9
atleast on mine a 550 motor will not work for 2 reasons. 1) the pinion would need to be a larger size so it could be spaced back far enough. and 2) the lower link would have to be at 90* angle from the axle due to the extra can length
benoj is offline   Reply With Quote
Novak M2 Dig with 23T 550 motors.......? - Similar Threads
Can a Moped handle two 23t ,540 motors? TheHeadHunter Electronics 2 04-28-2008 08:30 PM
