Thread: got some questions and some problems
Old 03-11-2012, 05:35 PM   #1
Default got some questions and some problems
so i have an axial ax10 with 4 wheel steering and a 55t motor with the stock esc and a 3200 mah battery and i cant steer and drive at the same time but i dont know what i need to fix any one got a solution for me ?
i would also like to upgrade from my spektrum dx3 so that i can also run my dig and my 4 wheel steering seperatly but i dont know enough on any of the bigger remotes to just go out and buy one or even set it up correctly. any one got that info also ?
zacattack is offline   Reply With Quote
Old 03-11-2012, 05:39 PM   #2
Default Re: got some questions and some problems
check out this thread:
Yes you need an external bec
forbid89 is offline   Reply With Quote
Old 03-11-2012, 06:17 PM   #3
Id say get a good transmitter. The one I have which is considered old by some because its FM has a 3rd channel that can be independent for shifting or assigned to steering or throttle and would work perfect for 4ws system.
Crawler King69 is offline   Reply With Quote
Old 03-11-2012, 07:07 PM   #4
+1....nice link.....
Since I'm a Futaba fan, I say get a 4PL. Another cheaper choice is the FlySky GT3B........Hacked of course by Losikid......
Charlie-III is offline   Reply With Quote
Old 03-11-2012, 07:25 PM   #5
esc will help
ax10 is offline   Reply With Quote
got some questions and some problems - Similar Threads
Few questions and problems. SinCity Axial SCX-10 3 05-06-2010 12:10 PM
proline memory foams questions,problems 929freak Tires and Wheels 4 12-13-2008 11:29 AM
NIMH questions/problems Tacoma747 Electronics 6 11-25-2007 08:46 AM
more shock questions/problems vypr2002 General Crawlers 3 07-28-2007 07:16 AM
