03-25-2012, 04:26 PM | #1 | ||
Newbie Join Date: Mar 2012 Location: Usa
| Will this work with the Scx 10???
03-25-2012, 04:35 PM | #2 |
| Re: Will this work with the Scx 10???
tmk the flysky 3ch rxs do work with the axial 2.4ghz tx, but i could be wrong
03-25-2012, 07:47 PM | #3 |
Should I risk the $10?
03-25-2012, 07:50 PM | #4 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
why dont you just solder on some ant. wire?????
03-25-2012, 08:02 PM | #5 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: Will this work with the Scx 10??? |
03-25-2012, 08:07 PM | #6 |
I dont have one and dont I need the same antenna that was with the receiver
03-25-2012, 08:52 PM | #7 |
Rock Crawler Join Date: Mar 2011 Location: hampton
03-26-2012, 09:53 PM | #8 |
So Ill just buy some antenna wire , solder it on, and if that doesnt work just buy the reciever?
03-26-2012, 10:25 PM | #9 |
Pebble Pounder Join Date: Aug 2010 Location: Winfield
| Re: Will this work with the Scx 10??? i dont see it "not" working. essentially all your receiver wire is is a conductive surface to receive radio waves. so when you solder on your wire just make sure to shrink wrap or use elec. tape on the solder joint so you dont get interference from the exposed joint touching anything and it will be good to go. you might even be able to solder the new wire onto the board itself. (if this is actually where the wire broke at you can disregard the shrink wrap/elec. tape suggestion). you should be fine with no worries! |
03-27-2012, 09:48 PM | #10 |
| Re: Will this work with the Scx 10??? Ok Thanks that really helped
04-07-2012, 11:38 PM | #11 |
Went to my hobby store and they said that you cant solder on a wire what should I do! |
04-08-2012, 04:36 AM | #12 |
Rock Crawler Join Date: Oct 2011 Location: Canada
Run it without it. It's a 2.4ghz system, most 2.4 recievers have super short antenna and some don't even have an external one. Unless you plan on crawling 500 feet away... I don't think you'll notice at all. my antenna is curled up and jammed into the reciever box in a balloon, no effect on performance.
04-18-2012, 09:04 PM | #13 | |
| Re: Will this work with the Scx 10??? Quote:
Will this work with the Scx 10??? - Similar Threads | ||||
work rack for yota, scx t-rex | gardenwelder | 1.9 Scale Rigs | 7 | 12-03-2010 01:22 PM |
will MIP c drive work on scx-10 | jeepboy | Axial SCX-10 | 5 | 09-02-2009 07:09 PM |
