04-05-2012, 08:15 AM | #1 |
Newbie Join Date: Oct 2011 Location: clarksville
| pti goliath
Ok guys, I just bought a modified Goliath on ebay. Its got a tamiya teu 101bk esc and and integy 65t motor and a gear reduction of some kind. Here is my plans: I have a mamba monster esc i wanna use, but what kind of motor should i put behind it? Also the steering servo is shot, any suggestions for a high torque servo under $50? Another thing is i wanna make it 4ws, which looks simple because both axles have steering knuckles but the back is locked with a linkage on both sides, if i get two servos can i get a "Y" adapter and run them both from the steering port on my receiver? Any help is appreciated
04-05-2012, 11:56 AM | #2 |
| Re: pti goliath
i would put a motor with much power in it as you will be hard pressed to find any parts for it and they arent known for high strength
04-06-2012, 07:11 AM | #3 |
| Re: pti goliath
bump.... anyone?? is anyone running a mamba monster setup?
04-06-2012, 10:38 AM | #4 |
| Re: pti goliath
help!
04-06-2012, 11:44 AM | #5 |
| Re: pti goliath
you can use a mamba monster esc but not the motor that comes with it. for a motor look for a brushed in the 35t and up range and for a servo under 50 look at either the hitec 5645mg or for under 20 i like the towerpro 946r on hobbypartz.com or look into savox servos
04-06-2012, 07:55 PM | #6 |
| Re: pti goliath
ok thanks! i dont have the mamba motor, just the esc. 35t-55t ok?
04-07-2012, 09:24 AM | #7 |
| Re: pti goliath
seems nobody is trying the mamba monster?
04-07-2012, 12:09 PM | #8 |
| Re: pti goliath
most people dont as its way overkill for our uses as the castle sidewinder,mamba max, or mamba max pro works just as good in crawler applications. if you have a castle link to set it to crawler reverse and brushed reversing it will work perfectly fine
04-08-2012, 09:48 AM | #9 |
| Re: pti goliath
I do actually, thats why i thought it would work great, with a strong drag break, and all the flexibility of castlelink....
04-09-2012, 06:26 PM | #10 |
| Re: pti goliath
too much esc?
pti goliath - Similar Threads | ||||
Pti Goliath | CrawlerX | Newbie General | 2 | 12-24-2007 04:29 PM |
PTI Goliath? | NWDave | General Crawlers | 39 | 05-16-2007 01:27 PM |
How is the PTI GOLIATH?? | PeteDriver | General Crawlers | 9 | 12-21-2006 04:51 AM |
Pti Goliath | OldSchoolCrawler | General Crawlers | 6 | 06-13-2005 11:47 AM |
