*HELP!? Rear Steering ??? Radio Programming ??? ok so i want to know how program rear steering into a fly sky gt3b using the 3rd channel? or using a "y" adapter on channel 2 with my front steering servo? how do you program rear steer? i think i have it down how to mount the servo on the rear and get the links right but i dont know how im going to make the radio do what i want it too :/ |
Re: *HELP!? Rear Steering ??? Radio Programming ??? Is your radio hacked? If not there is no way to program rear steer. If so, check out the hack documentation it should answer all of your questions. |
Re: *HELP!? Rear Steering ??? Radio Programming ??? how to hack it? do i need the usb cable? |
Re: *HELP!? Rear Steering ??? Radio Programming ??? Try this.... Products - OverkillRC , you can buy the hack kit & do it yourself. |
Re: *HELP!? Rear Steering ??? Radio Programming ??? Quote:
Well im a radio technician and a tower tech so I know im comfortable with thr soldering but hows the ease of use in the remote is it still simple or is it all complicated after the hack? ie. Binding, End Points, Trim, Model Name, etc. |
Re: *HELP!? Rear Steering ??? Radio Programming ??? If your radio is hacked, the 2nd post has a link to 4WS. http://www.rccrawler.com/forum/elect...er-thread.html |
Re: *HELP!? Rear Steering ??? Radio Programming ??? The hacked radio is easy to use. There are step by step how to's if you search this site that will tell you everything you need to know. I have never used 4 wheel steer, but am confident that you can figure it out with the info provided on this site. |
Re: *HELP!? Rear Steering ??? Radio Programming ??? ok can anyone decipher the code i suck at abbreviated codes! http://www.rccrawler.com/forum/elect...ml#post3232065 |
Re: *HELP!? Rear Steering ??? Radio Programming ??? There is no code in there, that is just what the screen shows on the radio. the display is limited to certain characters and they had to use those with the hack. |
Re: *HELP!? Rear Steering ??? Radio Programming ??? like this, Activate 4WS mix Long click EPA 4 3 0 NOC Long enter i have no idea what that means, maybe end-point-adjustment and the enter button, the rest to me is a mystery.. numbers i have no idea what they mean, clicks? beeps? seconds?? |
The "long click" is the silver ~3/4" dia button on top of the radio, push it for ~1.5 seconds. Then, spin that so the "EPA" window is highlighted Etc........ |
Please correct me if I'm wrong. |
Well, that board in the kit goes in the control? And the slot I have to cut is for the usb or the 4cond plug? |
Re: *HELP!? Rear Steering ??? Radio Programming ??? The board is an interface card that goes between the computer and radio, the slot allows you to connect the board to the radio. I am saying that the programming will be more obvious when you get the radio and you are looking at it rather than just reading random stuff. |
