04-30-2012, 07:44 AM | #1 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| DId I kill my receiver?
So I put in a screw the other day and it pinched the positive and negative wires for my winch between the tube work and transmission. It actually caused a dead short because it pierced the + and - and when I tried to spool the winch in, it didn't do anything. Well I pulled the culprit screw out and cut and re soldered the wires together, now the winch won't spool in. It spools out fine. I'm thinking that I must have fried something in the receiver for channel 3 in. I checked it with a test meter and I get negative 12 volts when I spool out but no voltage when I spool in....time to buy a new receiver? Thanks, Tim.
04-30-2012, 07:52 AM | #2 |
I wanna be Dave Join Date: May 2006 Location: akron
| Re: DId I kill my receiver?
did you check operation using channel 1 or 2???
04-30-2012, 08:12 AM | #3 |
Everything works fine except for channel 3 in. *edit: are you asking if I checked winch operation with channel 1 or 2? I would have to rip the truck apart to check that. Last edited by War Pig; 04-30-2012 at 08:15 AM. |
04-30-2012, 11:21 AM | #4 |
Are you checking voltage between the winch controller and motor? Typically when a RX goes all channels are taken out so like someone else suggested try the winch in another slot, I bet its the winch board not the RX. |
04-30-2012, 11:33 AM | #5 |
Ah crap, I didn't think of that. I'm running one of the TZI winch controllers. I have two other new ones, I'll have to put one in tonight. Duh, something so simple.....
04-30-2012, 01:32 PM | #6 |
| Re: DId I kill my receiver? |
04-30-2012, 11:55 PM | #7 |
It was the winch controller.....sometimes it takes a helping hand to remove one's head from his ass. Thanks for the help guys .
05-01-2012, 12:01 AM | #8 |
Rock Stacker Join Date: Mar 2009 Location: Basement of Coyote Hobby
Yup!
05-01-2012, 12:56 AM | #9 |
No worries man, probably cheaper than a new RX.
12-17-2012, 06:38 PM | #10 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
The winch controller has a high power side and a low power side, and both are isolated from each other. You may have just fried a relay, or the small fet under the board (depending on what version you have) The relay is easy to replace, but fet can be bypassed even easier. |
DId I kill my receiver? - Similar Threads | ||||
I Want To Kill.... | RANOVRU | Chit Chat | 12 | 08-08-2010 06:18 PM |
8.4V Will it kill it? | scrapstang4545 | HPI Wheely King | 5 | 11-10-2008 10:28 AM |
Over Kill? | bdbolin | Axial AX-10 Scorpion | 9 | 11-12-2007 07:58 PM |
