05-10-2012, 06:38 AM | #1 |
| Practical LiPo charge cable!
I was annoyed by too short balancing cables and a general cable mess. I ended up extending a 20cm balancer extension cable to 50cm, and then tie it to my 30cm regular charge cable. End of cable issues! Here's what it looks like when attached. |
05-10-2012, 06:59 AM | #2 |
| Re: Practical LiPo charge cable!
looks good. I've been meaning to do that as well. I have a charger with the board though, I figured I'd just get extension cables for it.
05-10-2012, 07:59 AM | #3 |
What an excellent idea! They should all be like that. Thanks for sharing.
05-10-2012, 09:28 AM | #4 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
The same place you got your charger and LiPo has these... HobbyKing R/C Hobby Store : JST-XH 2S Wire Extension 20cm (10pcs/bag) |
05-10-2012, 11:02 AM | #5 |
| Re: Practical LiPo charge cable! That's what I used for base material. As with all other balancing extension cables commercially available (that I've found) they're only available in 20cm length though. The problems
05-10-2012, 12:03 PM | #6 |
| Re: Practical LiPo charge cable! |
05-10-2012, 01:50 PM | #7 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
my charger came with instructions not to go longer then so many inches to my charge lead, that might hold true to balance taps as well....just maybe they are short for a reason.........bob .... |
05-11-2012, 04:30 AM | #8 | |
| Re: Practical LiPo charge cable! Quote:
Incidentally I used cables from a scrapped computer PSU, which happened to be 18AWG, the same gauge as the power charge cable... The only real downside I see with my arrangement is if you want to use more than one type of LiPos. I use only 2S, so it's a 2S balance cable. If I was to use 3S and 4S as well, I'd either have to use separate charge cables for each type, or attach more balancing connectors at each end. | |
05-11-2012, 08:33 AM | #9 | |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
The only other method of creating an extension for those of us who use more than one type of battery would be to use a charger that utilizes a balance board and extend the balance board cable to get it out by the discharge connector. Otherwise you'd have to sink each type of cable within the charge cord bundle. Marcus | |
Tags |
balancing cable, charge cable, lipo charge |
Practical LiPo charge cable! - Similar Threads | ||||
How long to charge lipo | WestTxRc | Electronics | 8 | 11-02-2011 04:42 PM |
Lipo Charge Box | WestTxRc | Electronics | 1 | 10-31-2011 10:35 AM |
Lipo won't charge | Serolf | Electronics | 4 | 02-19-2011 09:36 PM |
Lipo charge time? | ba450crf | Electronics | 10 | 06-06-2010 10:44 AM |
Lipo charge issue... | solomon7 | Electronics | 6 | 03-12-2010 03:53 PM |
