05-12-2012, 12:30 PM | #1 |
| Lipo packs charging c experiences needed...
Turnigy 3s2200mah40c packs. Specs on hk site say a charge rate of 5 c is acceptable, that's 11amp charge rate lol. As of now I've been charging at close to 1.5 c. Anybody charging quicker?
05-12-2012, 01:08 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: Lipo packs charging c experiences needed...
You can but it will diminish useable cycles. I only go 2.5c on my 5c packs only because the cheaper packs tend to be over rated by the manufactures. But I know quite a few who charge at 5c with no issues. I like to be safe is all. |
05-12-2012, 02:16 PM | #3 |
Yeah a lil bit overrated, the reason too much of a cheap pack seems to work for me Not looking for these packs to last forever but also don't want a safety hazard, they're so cheap I replace after a year or so. Will start with 2.5c and go from there. Thanks for the input. |
05-12-2012, 07:26 PM | #4 |
I charge at 1c regardless of what the pack says it can be charged at. What's the rush anyway? I have some GensAce packs that say they can be charged at 5c and some Sky LiPo that say to charge at 2c but I find that they charge better at 1c. The times I've charged the GensAce packs at more than 1c and run them they were way out of balance (one cell at 2.9v and the other at 3.5v). When I charge at 1c they seem to be more stable when run hard. This may be just a bunch of mumbo jumbo, but it's what I see when I charge. My competition packs are 800mah 3s 40c packs that I charge at 1c. Since you store the LiPo at about half charge anyway (3.8v/cell) then the charge time is usually about 30-45 minutes at 1c. |
05-12-2012, 08:06 PM | #5 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Lipo packs charging c experiences needed... It doesn't make any difference to a lot of people since their basic charger likely only charges at 5-7A. I, like you, have been charging at 1.5C on ALL my LiPo's (95% from HobbyKing) and they seem to be lasting quite well. Some are over 5 years old.
05-12-2012, 08:53 PM | #6 | |
| Re: Lipo packs charging c experiences needed... Quote:
Yeah my chargers max at 5amps so that would be a tad over 2.5c. Wow 5yrs eh, I've usually given em away or salt water dunked em by 1.5yrs or so. | |
05-12-2012, 09:35 PM | #7 |
Pebble Pounder Join Date: Apr 2012 Location: Apple Valley MN
I usually charge the smaller lipos (2200mAh) and under at 1c. Anything larger I go to 1.5c. I do charge a couple of my larger flight packs (have a ton of electric planes) at 2c.
05-12-2012, 10:20 PM | #8 |
RCC Addict Join Date: Aug 2009 Location: Earth?
As far as I know. 1C is equil to 5 amps. Not saying Im right. But I would like to know for sure. |
05-12-2012, 10:22 PM | #9 |
| Re: Lipo packs charging c experiences needed... |
05-13-2012, 12:57 AM | #10 | |
Most basic 5A chargers are 50W and the wattage is the governing factor, so using Ohm's Law... I(amps)=P(watts)/E(volts) A 3S 2200mAh LiPo will only charge at 4.17A max on a 50W charger, based on 12v. Likely a little less due to wiring and connection losses. | |
05-13-2012, 04:32 AM | #11 | |
Rock Crawler Join Date: May 2012 Location: Upland
05-13-2012, 05:38 AM | #12 |
Pebble Pounder Join Date: Mar 2012 Location: Warren, Mi
Depends on what I am doing. Just bashing around the house I charge at 1c. At the track I charge around 4c. No ill effects yet, but I went into it willing to scrap a battery if it became questionable and just replace it.
05-13-2012, 08:02 PM | #13 | |
The amperage isn't the limiting factor here, the wattage is. If it were the amperage, then you should be able to charge any LiPo at 5A. 2S and 3S are poor examples since they sorta sit in the 50W charger output range. Take a 4S (14.8v) on your 50W charger and see if that will charge at 5A. Not even close. | |
05-13-2012, 08:16 PM | #14 |
Somewhere around 3amps for me on 4s5000mah30c's for the mt's. Was confused when I first saw it, then duh set in |
05-13-2012, 10:03 PM | #15 |
1c, always.
05-13-2012, 11:47 PM | #16 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
I have no fears of lipos. I am scared as hell of Nimhs. I won't charge them. I am a wee bit more agressive charging my lipos than some people. I go for just shy of the max charge rate on the pack. 4-5C None of my bigger packs are rated below 45C discharge however. I always buy the highest C rated batteries I can find. Except Maxamps. I stay far away form those. I have 360 mah 20C Turnigy Rhino packs that are 4 years old and get 4C charge rate. 15 minutes max. Zero temperature fluctuation after a charge. I store them fully charged. Still charge to full capacity and balance perfecty. I have 2250 mah 65C Nano techs that I max my Accucell 6 charger out on. No issuse at all. HK packs are so cheap, I'll just toss them if they start to act funny. I have had nothing but great luck with lipos over the last 5 years of so. |
05-14-2012, 12:49 AM | #17 | |
05-14-2012, 12:50 AM | #18 |
Lipo packs charging c experiences needed... - Similar Threads | ||||
charging aaa packs | Dubs Chops | Electronics | 7 | 01-10-2009 02:56 AM |
Fast Charging 2/3 A packs | Harvo | Newbie General | 9 | 05-15-2008 02:04 PM |
charging 2/3A packs | ecoli | Electronics | 5 | 09-12-2007 04:14 PM |
charging 2/3a packs | Calderwood | Electronics | 8 | 07-31-2007 03:45 PM |
