06-09-2012, 06:55 AM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
| Do I have a bad steering servo?
Been building a used wraith I traded for, that came with a hobbywing 60amp esc and a 4600kv 9 turn motor. I installed a new CC BEC set at 6 volts, a used JR 8711 from my berg, and I am running 7.2 2 cell lipo's. Got it running and when the front wheels are up in the air they shake like they are freezing to death, and when I give it any throttle at all the fronts turn dead left and I have almost no control. I believe the servo is bad any thoughts?
06-09-2012, 07:03 AM | #2 |
Rock Stacker Join Date: Mar 2012 Location: U.K.
| Re: Do I have a bad steering servo?
did you remove the red wire from the esc to receiver because that may cause a problem and do the batteries have a high enough c rating to handle your ecs and servo?
06-09-2012, 07:31 AM | #3 |
Only wire in the rx is the signal wire of the y harness, the c rating is 30 continuous
06-09-2012, 12:54 PM | #4 |
Hit the LHS for a new 7955 hi-tech, problem solved!
Do I have a bad steering servo? - Similar Threads | ||||
steering is bad after diff rebuild! | EricTheRitt | Losi Mini-Rock Crawler | 2 | 09-07-2011 03:49 AM |
bad servo | brushlessnut | Losi Micro-Rock Crawler | 11 | 01-12-2010 04:10 PM |
Servo Gone Bad? | cmac888v2 | Electronics | 0 | 04-28-2008 12:34 AM |
