06-18-2012, 09:19 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| RC4WD Modified 55t, Novak Terra Claw 35t Problems...HELP! so i just got my 55t motor from rc4wd (installed), and my novak 35t terra claw (not installed still in box) and i installed it on my honcho based wraith hybrid with all metal cage work, this bitch is heavy, so im using a 18t pinion for some wheel speed, wrong! i took her out crawling twice and it feels like it has no balls at all! i go up to a rock, and it crawls fine but when it gets under some pressure like into a bind where the wheels should spin it wont the tires just seize up and nothing moves, full throttle and nothing, im using a venom 2s lipo 30c 5000mah with the losi msc12l night crawler esc which ive used in multiple rigs and its a great esc for a 2s application and price, but i dont want to burn it up, what am i doing wrong? and also my drag brake doesnt seem to brake hard enough to stop the rig i programmed it into crawler mode but apparently my rig might be to heavy for the drag brake to hold it? idk im a shortcourse guy and thats all i know as far as gearing combos, ive been crawling for under a yr and im still getting to know things so please dont burn me just looking for some honest seasoned help asap. thanks guys, aaron g, Last edited by Big Tex; 06-18-2012 at 09:34 AM. |
06-18-2012, 01:30 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: chico
| Re: RC4WD Modified 55t, Novak Terra Claw 35t Problems...HELP!
First how heavy is heavy. Second thats a large pinion. I'd try the 35t with a 12/87 combo, you will never be happy with wheel speed with a 55t motor on 2s that's my 2cents.
06-18-2012, 03:09 PM | #3 |
idk 8 or 9 lbs heavy? i have the 35t terra claw and 14t-20t pinions so 14t pinion on the terra claw 35t? |
06-18-2012, 03:18 PM | #4 |
Quarry Creeper Join Date: Aug 2011 Location: Spalding, Lincs, UK
Is it one of RC4WD's sealed cans? I had one of these that was just gutless as well as slow. It ended up straight in the bin. If you can get them in the states, Ansmann Roxx motors are okay if you are on a budget, comes in 50, 55 and 80t, and fairly pokey, plus they are rebuildable if you know someone who's a wizz with brushless motors. |
06-18-2012, 03:21 PM | #5 |
yeaa it was the $10 motor lol ordered it just to try it out, it might as well be a paper weight now, im definitely swapping out to the 35t terra claw,
06-18-2012, 03:28 PM | #6 |
I've got a mixture of motors in my trucks, from a tuned up 55t Novak, a HH motor I got in a trade, 35t I think, plus I get good results with Tamiya Sport tuned black cans and really low gearing (on 2s Lipo only) I've used the Roxx 50t motors in my Tamiya Dagger trucks that my kids use, just quick enough to keep them interested but slow enough that crashes aren't that big a deal. |
06-18-2012, 03:44 PM | #7 |
I think a 12 tooth pinion would be a better choice with the 35t. What the tooth count on your spur?
06-18-2012, 04:04 PM | #8 |
stock 87t? its a factory wraith trans?
06-20-2012, 12:25 AM | #9 |
I run a tekin 35t in my wraith 12/87 and love it 2s or 3s
06-20-2012, 07:59 AM | #10 |
^^sweet! im actually soldering up the motor leads today and installing it, but it your wraith is light as helll (just a general weight) compared to my 9lbs bitch, wouldnt the gearing need to be different that a wraith? just curious guys.. |
06-20-2012, 08:13 AM | #11 |
The wraith is actually pretty heavy. Mine doesn't have any metal other than the aluminum upgrades and a bit of weight in the tires. And with a driver and spare tire it's about 9lbs
06-20-2012, 10:08 AM | #12 |
hmm, didnt know that, a buddy has one and after i set mine down i get his outta the truck and its light as hell, maybe its just my brain going retarded for a moment, but im going to try this combo today and see how the 12t goes i got in today a full set of robinson racing pinions from 10t-20t 48p 3mm shaft |
RC4WD Modified 55t, Novak Terra Claw 35t Problems...HELP! - Similar Threads | ||||
Novak Terra Claw Crawling Brush Motor 55T | barshots | Redcat Crawlers | 12 | 03-05-2011 05:37 AM |
Novak Fifty five vs. Novak 55t Terra Claw | Axial32 | Newbie General | 9 | 03-01-2011 07:40 PM |
Axial XR10 steering link and Terra Claw 55T motor issue | beb | Axial XR10 | 12 | 01-28-2011 06:04 AM |
Novak Terra Claw 55T motor question. | arctichorse | Electronics | 2 | 01-14-2011 12:47 AM |
