06-19-2012, 10:58 PM | #1 |
Newbie Join Date: Dec 2011 Location: Canada
| mamba max pro for MOA
hey guys, first of all sorry if this question has been asked, but i was wondering if a mamba max pro would be a good option for my MOA on axle rig, its 11.1V 30C lipos, 2, 35T holmes hobbies torque master pro's ( but also have some cheap 20T motors for when the holmes are getting rebuild) and 2 hitec titanium geared servos (470 ounce i believe) for axels i have the bully comp 2.2 If you guys have any good input id be happy to hear! need to get a new esc ASAP |
06-20-2012, 01:35 AM | #2 |
| Re: mamba max pro for MOA
The MMP is a great esc. Lots of the guys with MOA rigs are using dual sidewinders, as am I and i love it. The MMP is a bit on the larger side, but if you have the room and don't mind the bit of extra weight I'd use them. Another option if size is an issue is the Tekin FXR. 2 of those put together is quite a bit smaller than the MMP. Check out the MOA sections and see what's working best for everyone.
06-20-2012, 04:58 AM | #3 |
When my son built be a 2.2 Bully, it started off with a single Mamba Max (older version) ans a servo dig with 2 (decent) 35T motors & 3S. It worked fine. Later went to dual Mamba Max ESC's and it was even better. Since you're 2.2, why 2 servos?? You WILL want an external BEC for them. |
06-20-2012, 06:58 AM | #4 |
You will need some sort of dig for that but the ESC should hold up just fine to that. As Charlie said, you'll need an external BEC because the internal one won't push two of those servos, let alone 1.
06-20-2012, 08:28 AM | #5 |
Oh I do have a 10 amp CC bec. And two servos because I love rear steer. So one mmp should be able to do some job. The for print doesn't bother me So much. I can find and make room |
06-20-2012, 10:07 AM | #6 | |
| Re: mamba max pro for MOA Quote:
Yes, the Mamba Max Pro is a great "medium sized" ESC. If your rig will get wet, maybe look at the Holmes Hobbies BRXL, you can get them waterproof. It's like a waterproof Mamba Max Pro. | |
06-20-2012, 12:01 PM | #7 |
| Re: mamba max pro for MOA |
06-20-2012, 12:37 PM | #8 |
06-20-2012, 01:17 PM | #9 |
Awesome thanks for the input guys! I would like to go with the brxl and get a Holmes setup going. But my hobby shop doesn't deal with Holmes. And I can get the mamba in 5 days from Them. If I ordered the Holmes my self it would take to long. I want to crawl now! Had an ae-2 but she went up in smoke. So mamba max pro it is!
mamba max pro for MOA - Similar Threads | ||||
Mamba Max Pro - vs - Mamba Max Pro SCT | rctoyguy | Electronics | 1 | 06-08-2012 06:19 PM |
