07-24-2006, 03:03 PM | #1 |
Quarry Creeper Join Date: Jul 2006 Location: Salem
| EVX Questions
I have a evx and am going to do the one bat mod. I am curious if any one has taken the box apart and made the conection inside rather then having those 2 extra wire hanging out for no reason? Also I have heard people talk about using a rx batt pack is this nescessary? and if so you take the red wire out of the plug that plugs into the reciver? I will be using 2 servos one is Airtronics #94357 with 100 oz-in and a Traxxas 2055 with 80 oz-in. Wich servo shouldl I use for the front steer and then rear steer. One last question should I solder the motor wires right to my motors or should I have plugs?
07-24-2006, 05:41 PM | #2 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
I always solder my motors to the ESC. The bullet connectors are not very efficient. I kept both of the battery leads when I did my mod. I connected three cells to each. Three in the front and three in the back. The ESC is conveniently in the middle.
07-24-2006, 07:11 PM | #3 |
Thanks
07-24-2006, 07:19 PM | #4 |
RCC Addict Join Date: May 2006 Location: USA
i always use bullet connectors, if you have to do work on the motors it would be a pain if its always attached to the esc. also what if you want to use the motors in another truck, or if 1 motor dies? bullet connectors might not be the best choice, so use deans connectors most people seem to like them. when i ran my evx with the mod i didnt even need to use a receiver pack, your servos arnt very powerful so try it first without the pack.
