07-26-2006, 08:17 AM | #1 |
Quarry Creeper Join Date: Jun 2006 Location: boondocks
| 35t lathe+moped=?
would a moped run a 35t lathe in a tlt? if so would be have more torque or more speed? feel free to steer me towards the all mighty search button
07-26-2006, 09:02 AM | #2 | |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
Have more torque and speed than what?What are you comparing it to?Im pretty sure the moped can run a 35t lathe. | |
07-26-2006, 09:22 AM | #3 |
Pebble Pounder Join Date: Nov 2005 Location: Lititz
swamp rat, i'm runnin a 35t lathe motor with a moped esc in my tlt. this combination has torque and wheel speed, but if you plan on running this setup i suggest you get a 12 tooth pinnion and 87 tooth spur, both 48pitch. crawlaholic |
07-26-2006, 03:58 PM | #4 |
well in the trade if he can find it i'll be getting a 35t lathe so i needed to know this, crawlaholic, where will i be able to find the pinion and spur online?
07-26-2006, 04:17 PM | #5 |
Pebble Pounder Join Date: Mar 2006 Location: igloo, Alaska
| http://www2.towerhobbies.com/cgi-bin...&I=LXEX10&P=ML Pinion http://www2.towerhobbies.com/cgi-bin...?&I=LXEY28&P=7 And i think this spur will work depends what trany your using. |
07-26-2006, 04:59 PM | #6 |
9/10 going to get a pede tranny since theyre more common and arent expensive thanks guys |
07-27-2006, 11:55 AM | #7 |
Go with a Stealth. You can pick on up just as easy on E-bay. They are stronger, lighter and you can buy a RPM kit to lower the gears in the tranny.
