07-27-2006, 07:14 PM | #1 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| Need help getting rid of Reverse delay.
I have an LRP F1 Pro Reverse Digital speed control. I am trying to figure out how to get rid of the reverse delay. I have heard of people being able to program the delay out on speed controls without an adjustible delay. I have tried setting it up so there is a delay in fowards, but there is an 8 second limit on reverse, so when I switch it, the motor only goes fowards for 8 seconds. Does anyone have any solutions for this, besides getting a new speed control. Even if I could lessen the delay that would be good because 1 second delay is way too long. Thanks |
07-29-2006, 08:14 PM | #2 |
So I guess there isn't a way to get rid of most of reverse. Oh well, Ill leave this up incase someone has a solution.
07-29-2006, 08:49 PM | #3 |
Well,it's on a Rebel II,but it should work the same. Most of the time you want instant foward to reverse. I tried several times to set the foward to reverse delay on the Rebel II to as little as possible,but the best I could do was about 1 second delay. Most cases that will be to long. I noticed that the reverse to foward was instant,or dang near instant........So I just swapped the wires on the motor and now it's golden. On the motor,put the + wire on the - side and the - side on the + side. Then just flip the 2nd channel switch on your radio. Should be good to go,assuming you have a motor with zero timing. If you have a motor with say 10 degrees advanced timing,doing this you'll end up with 10 degrees retarted timing. If your endbell is adjustable,just adjust accordingly and your good to go. |
07-29-2006, 09:03 PM | #4 |
That wont work I already tried that and since my speed control has 8 second timer for reverse I can't do that, beause it will stop after 8 seconds and I have to go the other direction to make it go again.
07-29-2006, 09:07 PM | #5 | |
RCC Addict Join Date: Mar 2005 Location: Saginaw
| Edit: Looks like TMXONR beat me to it That would work fine, except he said - Quote:
07-29-2006, 09:12 PM | #6 |
Well,sorry I couldn't help,it worked very well for my sons Twin running the Rebel II.
07-29-2006, 09:28 PM | #7 |
The thing I don't understand is that the instructions say "No reverse delay".
07-30-2006, 04:21 AM | #8 |
Pebble Pounder Join Date: Dec 2005 Location: Highlands Scotland
I would try asking the question on this site http://www.lrp-electronic.de/e/main_frameset_e.htm It however looks like this is a built in design and cannot now be removed from the settings shame cause I was thinking of getting one of these I might just go for a moped now then Last edited by ede670; 07-30-2006 at 04:44 AM. |
07-30-2006, 08:34 AM | #9 |
Thanks for the link. I searched the forum and LRP says that it is supposed to have the delay. They sound like abunch of idiots over there. If something is supposed to have a delay, DONT SAY IN THE MANUAL THAT IT DOESN'T.
07-30-2006, 09:14 AM | #10 |
Exactly what I was thinking when I was looking through the site for you. I would say you could get a refund if its a new esc for miss information in the packaging they are not supposed to be advertising it as one thing when it in fact cant do that. Its worth a try anyway |
07-30-2006, 02:35 PM | #11 |
Hmm I should try that, but I voided my warrenty when I put Deans Plugs on it. I bought the speed control for my RC10B4 when they first came out, but after I went brushless it sat around for a while collecting dust. Its old but it wasnt used much. Im gonna go email them.
