07-14-2012, 06:35 PM | #1 |
Rock Crawler Join Date: Apr 2011 Location: Sonoma County
| Adding balance plugs to batteries
Can I do this? Or will something go horribly wrong? |
07-14-2012, 09:20 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| Re: Adding balance plugs to batteries
I've only been using lipo's for a few months so i don't know everything about them, but the Balance plug is to "balance" the individual cells. That is a 2s (2 cell) battery, and it needs to have the cells balanced from the cutoff (usually 3.20v) to max charge (4.20v per cell). I know that 2s batteries have 3 wires on the balance plug, and 3s have 4, so i know that white wire is used for something..... I'm assuming you want to put a deans on to charge the battery? Just buy a cheap Accucel 6 charger (i think its 7.99 for the charger and 9.99 for a dc power supply that does 5amps) from Hobbyking, it charges up to 6s and has a balance slot and a positive/negative slot that you can solder on whatever connector you need. I know that some lipo's have a max amp limit for charging, I'm not 100% sure but i wouldnt try charging that lipo at more than 200 millamps (based on the 160mah rating). I bought 6 of the 2200mah 40c 2s Zippy lipo's from Hobbyking, i charge them at 6 amps (I was told they can be charged up to 8 or 10 amps, not sure). Takes ~30 min to charge and last ~45 min on my scx10 with a 35t motor.
07-14-2012, 10:45 PM | #3 |
Micro Deans in addition to balance plug...... no problem, go for it. Switch to Micro Deans and eliminate the balance plug...... bad idea, then how do you balance the cells? |
07-15-2012, 12:24 AM | #4 |
| Re: Adding balance plugs to batteries Right. Thanks. I want to splice the red and black wires and put a deans plug on that. I would still use the three wires to balance during charging. I would use just the red and black wires, now split off to plug the battery into the rig.
07-15-2012, 02:28 AM | #5 |
Take your time, do one side at a time, and you should be fine.
07-15-2012, 02:35 AM | #6 |
Newbie Join Date: Dec 2004
No problem at all, just make sure you don't short the wires when doing it. Cut ONE wire at a time of your cutters will de missing a bit of metal afterwards (don't ask how I know this, it sure does SPARK!)
07-15-2012, 04:48 AM | #7 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
Use a meter and make sure those are the correct wires you need. I just saw an article somewhere that the balance wires are not color coded the normal way. Sent from my Galaxy Nexus using Tapatalk 2 |
Adding balance plugs to batteries - Similar Threads | ||||
Lipo Balance Plugs | THnCS | Electronics | 4 | 11-22-2010 06:56 PM |
LiPo - Balance/charge or charge then balance? | BoredGord | Electronics | 8 | 05-17-2009 08:18 AM |
Balance plugs? | LIKES2CRAWL | Electronics | 4 | 02-19-2009 10:07 PM |
adding batteries to pack | some_guy | Electronics | 8 | 10-30-2007 12:49 AM |
