07-19-2012, 12:04 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
| mamba micro pro
i received my new mamba micro pro for a mrc and will be hooking it to a Br00d frenzy motor the esc has 3 wires and the motor only has 2 what do i do with the 3 wire on the esc red white black and the motor is red and black
07-19-2012, 12:06 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: mamba micro pro
you can unsolder the white wire or just zip tie it to the others, its not needed unless your running brushless.
07-19-2012, 07:57 PM | #3 |
| Re: mamba micro pro
At most, I would shorten it up but tape the end of it. You never know when you may want brushless and it can be a PITA to solder to these boards to add the white wire back in.
07-19-2012, 11:23 PM | #4 |
| Re: mamba micro pro
Yep...either cut it off close to the board or just zip tie it out of the way, but be sure to tape up for heat shrink the end so it doesn't contact anything. You only need the red and black wires. Be sure to hook it up to your Castle Link and check the settings |
