Thread: heatsink came off of my ae-2
Old 08-10-2012, 03:58 AM   #1
Default heatsink came off of my ae-2
So, While waterproofing my Axial AE-2 with liquid black tape the heat sink came off. Can I use artic silver to re-attach the heatsink? That stuff doesen't hard so do I have to worry about the heatsink comming off from normal running vibration? Or should I use normal heatsink mastic. BTW if you didn't knoe artic silver is a mastic used to couple a heat sink to a cpu in computer building. Just wondering what your guys thoughts were. Thanks again.
ek9808 is offline   Reply With Quote
Old 08-10-2012, 05:06 PM   #2
Natedog's Avatar
Default Re: heatsink came off of my ae-2
I don't have stock esc, but have had many different esc's....what held it on before and is there some heatsink compound residue on it? Most of those products are all very similar and should work fine, Radio Shack or Fry's carry's heatsink grease.
Old 08-10-2012, 06:57 PM   #3
I had the exact same problem occur while doing the exact same thing. My solution was to use CPU thermal compound on the heatsink. I then used a couple of zip ties to secure the heatsink. Not too pretty but it works.
ZeroDark30 is offline   Reply With Quote
Old 08-11-2012, 02:54 AM   #4
Figured it out. Found out artic silver makes a thermal epoxy. I ordered some up so we'll see how it works out.
Old 08-15-2012, 01:38 PM   #5
The artic silver epoxy worked out perfect. The esc heatsinks now stays on on it's own and seems to be working better. The artic silver transfers the heat to the heatsinks more effintently now I guess. The esc heatsinks does get warm pretty quick now doesrnt ever get too hot. It was pretty cheap too. Ordered it from Walmart.com and got it in 4 days. Pretty quick considering I'm in Hawaii.
heatsink came off of my ae-2 - Similar Threads
heatsink for wraith motor? isac Axial Wraith 4 05-25-2012 07:38 PM
Heatsink and fan? Drvnbeing Team Losi Comp Crawler 3 11-01-2009 09:50 PM
Cobalt heatsink Mortimer Snerd Electronics 13 05-16-2009 09:34 AM
My heatsink came loose! chops1sc Electronics 2 04-22-2009 07:34 PM
540 motor heatsink Azcats1 Electronics 0 09-17-2006 10:31 PM
