08-01-2006, 05:35 AM | #1 |
Rock Crawler Join Date: Sep 2005 Location: IDK
| HS-5925MG Good Or Not for txt crawler
Heey im planning of buying a HS-5925MG servo but do u realy need a field programmer for it the packeging says so. Its pulling 7,5 kilo's at 4,8 volt's and 11 on 6v Thank you |
08-01-2006, 07:22 AM | #2 |
Quarry Creeper Join Date: Feb 2006 Location: Glenrock
If you get a nice computer radio you can program the srevo with that. The field programmer has more programming options but I think it is overkill for a crawler.
08-01-2006, 12:28 PM | #3 |
I dont have a computer radio and im not buying one either. but can i use the servo normaly with just a normal 2 channel radio??? greets |
08-01-2006, 01:14 PM | #4 |
To my understanding, a digital servo will constantly fight itself if you don't adjust the End Point Adjustment and center point to match your rig which will decrease your run time significantly and perhaps burn up the servo. You might be able to run the servo with your radio if you take the rig to the LHS and have them program the servo for you. Give them a call and see if they would do that and how much they would charge.
