08-03-2006, 09:49 AM | #1 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
| HowTo: repair water damaged electronics
im doing a how to repair wter damaged servos/escs. this is a cheap, easy, and effective way to do it. things youll need: WD40 clean rag for servos: open up the bottom of the case where the electronics are, pull out the motor and board so it is empty, spray the inside and electronics lightly with WD40 then dry off with the rag. make sure the board is completely dry before putting it back inside, close the case and seal it. for sealing i suggest plastidip or just use glue, you can also use electric tape. to seal the rubber peice where the wires go in just use some super glue. you can do the same thing for escs, im not sure about sealing them with plastidip though. i hope this helped anyone who was having trouble. |
08-03-2006, 11:53 PM | #2 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
Sounds like a way to water proof to me, not repair...
08-04-2006, 05:08 AM | #3 |
Pebble Pounder Join Date: Sep 2005 Location: minocqua
he is saying that the wd40 will displace the water, but if you just jam it back into the case, it wll have no where to go. and it isnt a shurefire thing, for me, i have found that if i DO NOT try to drive it as soon as it gets wet, i can just pop the case appart, and dry it out with a hair dryer, then let it sit for a day or two, and put it back together, it will work. i have had my runner plus esc's submurged once for one, ant the other twice. and i have had no problems with getting servos getting wet. |
08-04-2006, 10:37 AM | #4 |
Ya, I guess that makes sense. Sounds like it would be something you would have to catch early though.
08-04-2006, 02:29 PM | #5 |
Newbie Join Date: Jun 2006 Location: Van, river... you get the idea
For electronics exposed to water (fresh or salt), isopropyl alcohol (better known as "rubbing alcohol") is a far better solvent to flush water away than WD-40. Leaves no residue behind, helps any trapped water evaporate faster, and evaporates quickly itself. And, as already mentioned; removing the power source ASAP, and not using the gear after the water exposure until it's cleaned and dried, is the best way to minimize/eliminate any chance of damage. |
08-04-2006, 02:47 PM | #6 |
Quarry Creeper Join Date: Jul 2006 Location: Snover, MI
the rubbing alcohol sounds like it would work better cause like he said it evaporates water very quickly, not that wd40 wont do the trick but rubbing alcohol would do it even faster.
08-04-2006, 02:54 PM | #7 |
i bet if you started the rubbing alcohol on fire it would get rid of the water VERY fast |
08-04-2006, 03:22 PM | #8 | |
Rock Crawler Join Date: Dec 2005 Location: Borderland Tejas
08-04-2006, 03:31 PM | #9 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
08-05-2006, 01:29 PM | #10 |
this doesnt repair it after youve already burnt it out, this helps it get dried out after its been splashed or gone under water
08-06-2006, 10:10 AM | #11 | |
Newbie Join Date: Aug 2006 Location: Parker
08-06-2006, 10:37 AM | #12 |
Quarry Creeper Join Date: May 2006 Location: Chandler
It's probably garbage now. Thisis something that you have to jump on right away.
08-06-2006, 05:57 PM | #13 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
For the most part, electronics are ok with getting wet as long as there is no power source connected to them. So, this may work out fine if say, you accidentally spilled a drink on your ESC while it was sitting unconnected on your bench. But once you've "smoked" it, it is usually too late. Just drying it out won't save it.
08-08-2006, 11:45 PM | #14 |
Rock Crawler Join Date: May 2005 Location: In front of my comp
I've had good luck with just laying them out in the sun to dry. |
08-09-2006, 12:57 AM | #15 |
Rock Crawler Join Date: Aug 2005 Location: Alabama
So I can take my EVX apart since it aint working and just putting some wd-40 or the rubbing **** on there and that will fix it?
08-21-2006, 11:57 PM | #16 |
Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
sounds like an ider. but for me when i got water in my servo it went crazy tunring and going physco. so i just left i for 3days then i plug it in too see if it still works and its fine. i am still using that servo today
08-22-2006, 01:03 AM | #17 | |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
Depends on the water damage, obviously you won't be able to repair an esc when its melted into the chassis[my evx basically]. This is simply one way to clean out very minimal water out of an ESC. Best thing to do, just go ahead and waterproof the stuff that you can easily. It can NEVER hurt to put your receiver in a case or balloon, even to protect against dust it'll help. Its like, when I see a guy who toasts his receiver in his nitro because he was lazy and it got splashed with nitro; all I can do is laugh. | |
