08-03-2006, 01:26 PM | #1 |
Newbie Join Date: Aug 2006 Location: Columbia
| Whats the deal with Sub C, AA
In reference to building a pack with either of these two batts, will a sub c cell perform better than a AA of equal capacity? Are there pros/cons to each type? It just seems that there are large capacity AAs, ~2000, while the preassembled subc packs are all down at ~1000-1400. Why is this? I did try and read a couple threads on AA pack building but I didnt see any answers to these questions. -Thanks edit again: Im referring to this size cell http://www2.towerhobbies.com/cgi-bin...?&I=LXMUE1&P=7 not sure if its termed sub c Last edited by thistleb; 08-03-2006 at 01:34 PM. |
08-03-2006, 02:49 PM | #2 |
after doing some interwebbing, it seems that AAs have a higher internal resistance than subc cells do. I would venture to say that therefore they have a lower peak current and are therefore not as well suited for high draw applications. Seems like a good answer to me but im not positive. Any insight?
08-03-2006, 03:05 PM | #3 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
the pack you posted a link to is actually a 2/3A pack, not a sub C. These cells are much smaller than AA or sub C. Current generation Sub C cells are around 4000 mAh and above. Yes, you are also correct about the higher internal resistance. Most compensate by adding an extra cell or two when they are building a pack out of off the shelf AA cells. |
08-03-2006, 08:31 PM | #4 | |
08-03-2006, 11:09 PM | #5 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I usually make my 2/3 AA packs with 8 cells to make up the difference.
