08-04-2006, 10:08 AM | #1 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| Mamba 25....Park 480 issues...cant get it to stop cogging
I have tried nearly every setting and combo of on the mamba 25 and under any stress the at low thottle settings it will just sit and rock back and forth....apply alot of throttle and it takes off.............any ideas? What settings are you guys running on your BL setups on the Mamba? |
08-04-2006, 10:47 AM | #2 |
Rock Crawler Join Date: May 2006 Location: Georgia
I use the lowest setting on starting power and timing. Seems to work great with the revolver.
08-04-2006, 10:50 AM | #3 | |
what batteries you running? | |
08-04-2006, 10:59 AM | #4 |
My first guess is that you have an old controller. Do you have access to a castle link? How long have you had the controller? |
08-04-2006, 11:11 AM | #5 | |
You have any in stock.......the LHS has had it on back order | |
08-04-2006, 11:18 AM | #6 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
just a guess but the 480 is rated at 22a continuous current and 28 max which is more than the mamba is supposed to handle although its not under much load it might juat need so much powwer that it wont run smoothly maybe
08-04-2006, 11:57 AM | #7 |
I am waiting on the castle links as well. Should have them by beginning of next week. I cant keep CC stuff on the shelves. Is the sticker like THIS or is it darker? The darker sticker is the new controllers. If you have a new controller I bet you have a short in the motor, or one phase is dead. The mamba has more than enough power for the Park 480. It is rated 25 amps continous, 50 amps burst for 30 seconds. |
08-04-2006, 12:03 PM | #8 | |
this is what I got | |
08-04-2006, 12:12 PM | #9 |
and it does work the motor I mean, if on flat ground it has no issues and plenty of tire speed. if I stop and try to slowly go up an obtacle it just sits there, stalls and trys to restart........tries to get going will move forward a tad then die again.
08-04-2006, 12:31 PM | #10 |
hmmmm. New controller, probably has at least the 3rd version of the software, so all is good there. Im gonna say the motor is probably bunk. Do you have another motor to try out? Do you have access to another ESC? Do you have a multimeter to test for shorts and continuity?
08-04-2006, 12:33 PM | #11 | |
08-04-2006, 01:01 PM | #12 |
First thing to check is continuity. Your meter either has a continuity tester, or you will use the resistance function. HOok up one lead to one motor wire, and test the other two wires for a good curcuit. Move the first test lead to another wire and test again. All should show current and basically no resistance. Testing for shorts is a bit harder, and will require taking apart the motor. With the way the setup is acting, it really seems that the controller has old programming (with a new sticker? not likely) or the motor has a bad phase. The new controllers will still make a bad motor run, albeit erratic and jerky. See if your lhs will let you test another motor. |
08-04-2006, 01:20 PM | #13 | |
08-04-2006, 01:28 PM | #14 |
resistance at a constant 00.1..................same varriance as the multi meter itself
08-04-2006, 02:00 PM | #15 |
this is the adapter plate on the motor that I just made.......yesterday. it lines up with the standard park screw pattern and has threaded 4-40 screw pattern for the 540 motor. uses the stock 4 countersunk bolts that come with the park 450 etc to mount it up |
08-04-2006, 02:03 PM | #16 |
Nice work, but we still havent solved your cogging :( What batteries are you running? didnt think of that yet |
08-04-2006, 02:08 PM | #17 | |
08-04-2006, 03:37 PM | #18 | |
8.4v GP 1100 pack | |
08-04-2006, 03:39 PM | #19 | |
08-04-2006, 05:10 PM | #20 |
Try programming the start up with a different setting yet?
