08-31-2012, 07:30 AM | #1 |
Quarry Creeper Join Date: Sep 2011 Location: Spring Texas
| Glitching problem
Hello guys, I have a problem in my Ridgecrest. Servo savox 1230MG, ESC BRXL, motor Tekin hand wound 35T, lipo nanotech 3 cells 1600 mah 25-50C, TX/RX Airtronics MX3. Alone stuff is brand new except radio. Steering OK alone, motor OK alone, when I steer motor stop and when I release motor start again. Is it a glitching problem because I m surprise BEC of ESC can give 5 amps at 6 volts....do you think I have to add an external BEC or there is an another problem? Thank you guys. Francois Sent from my iPad using Tapatalk |
08-31-2012, 07:42 PM | #2 |
| Re: Glitching problem
External BEC will likely fix your issue.
08-31-2012, 08:21 PM | #3 |
Tks for reply man, I ll try that this week end and I ll keep you informed Sent from my iPad using Tapatalk |
09-01-2012, 09:51 AM | #4 |
The savox servos are very inefficient, I would also suggest a BEC to see if it helps.
09-01-2012, 03:41 PM | #5 |
Tks John, I installed a BEC and now I break my motor so I ll see soon Sent from my iPad using Tapatalk |
09-01-2012, 06:42 PM | #6 |
So Bec installed, break motor during 4 hours with AA batteries. Results....same, I have steering and no motor. I have no bips when I plug the motor.... Motor is new and run with AA and when I plug lipos directly ( 2 or 3 cells ) it s ok too. ESC is new too and come from you Mister John. Tomorrow I ll try to reprogram ESC with stock set up. I tried to recalibrate but without bips...it s not easy Sent from my iPad using Tapatalk |
09-01-2012, 10:49 PM | #7 |
Episode 2 I swapr channel two with channel one and steering still ok and no motor or bip. Factory set up and still no bip. Led's on ESC. Fwd green light, reverse red light and neutral no light. Where I m confuse is that I have no bip on motor but when plugged directly to lipo, motor works. I tried an another motor ( I m no sure about it ) but still inop. Is there someone who have an idea? Sent from my iPad using Tapatalk |
09-02-2012, 12:13 PM | #8 |
Episode 3 and final I tried an another ESC and it s ok so my BRXL is fried, John we have to talk Sent from my iPad using Tapatalk |
Glitching problem - Similar Threads | ||||
glitching problem | Chodey24 | Electronics | 4 | 08-20-2012 09:35 PM |
***glitching problem*** | macattac-1968 | Electronics | 2 | 03-16-2010 11:54 AM |
Glitching Problem | Rjohn929 | Electronics | 4 | 10-27-2009 06:06 PM |
glitching problem? | driftin90 | Team Losi Comp Crawler | 1 | 06-22-2009 10:09 PM |
Glitching problem | calikingcrawler | Electronics | 3 | 04-16-2009 01:08 PM |
