Thread: Which ESC
Old 08-08-2006, 05:56 AM   #1
Default Which ESC
Which ESC should I get for my TxT Tekin Rebel 2 or Novak Super Duty XR
sfebenito is offline   Reply With Quote
Old 08-08-2006, 09:18 AM   #2
tekin rebel 2 is awesome. it has 5 amps at the bec which is the most any esc has. this gives you the most power for your steering servos so you dont need a receiver pack. i use the tr2 its awesome.
BrandonW is offline   Reply With Quote
Old 08-08-2006, 06:47 PM   #3
If your not in a hurry, check out the moped thread. They seem to be a pretty good esc and they are on the cheap. There are also a few super roosters on ebay right now.
I have a TR2 and I think it's great. Granted it is the only one I have run. I did have the on/off solder on the board pop off which kind of pissed me off since it was a 2 month old esc with only a few runs on it. Hopefully I just got a bad one. They are a royal PITA to open and I had to dremmel some of the heat sink to get to the rear screw to get the case apart. I just picked up a super rooster on ebay so I'm going to give that a whirl to see if there is a difference. Probably only difference I'll notice is not having a reverse delay though.
I don't think you can go wrong with either one. Just see what your budget allows.
TxCruzr is offline   Reply With Quote
