09-22-2012, 11:04 AM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: canada edmonton alberta
| micro pro
Can a mamba micro pro 4200 kv used for crawling,does it have a drag brake?
09-22-2012, 11:11 AM | #2 |
| Re: micro pro
Drag brake, yes. Smooth startup, no. Sensorless inrunner motors are generally unacceptable for crawling. The micro pro paired with a brushed motor and programmed for brushed operation will be alot better setup for crawling.
09-22-2012, 11:13 AM | #3 |
| Re: micro pro
If you mean the combo esc and motor then, yes and no, yes the micro pro has drag brake , and no the motor is to fast and sensor less
09-22-2012, 12:03 PM | #4 |
| Re: micro pro
What sould I get?
09-22-2012, 12:28 PM | #5 |
| Re: micro pro
Depends on , the rig and weight , gearing, what you are expecting and finally your budget |
09-22-2012, 01:33 PM | #6 |
| Re: micro pro
Have the mongoose in 1 chaotic mrc pro,have another pro I want to use brushless(3s),have a good buget.
09-22-2012, 03:23 PM | #7 | |
| Re: micro pro Quote:
I use the Xcelorin (discontinued) with the 18.5T motor and it works great and can handle 3S. See if you can find a used one. Either that or go brushed. | |
09-22-2012, 04:49 PM | #8 |
| Re: micro pro
The manual says 2s to 3s
micro pro - Similar Threads | ||||
Sidewinder micro vs Mamba micro pro | Mr. Ed | Losi Mini-Rock Crawler | 26 | 03-05-2009 06:14 PM |
