| | #1 |
| Makin "Bank" in ND!! ![]() Join Date: Sep 2005 Location: Μολὼν λαβέ
| What's the most cells anybody has run through an EVX with single batt. mod? I found all kinds of info and tech but nothing about max volts with only one batt. I want to run an 11.1 Lipo through mine (w/out letting out the smoke |
| Sponsored Links | |
| | #2 |
| . ![]() Join Date: Nov 2005 Location: Rock chucking territory
| I run 12 cells sometimes and have not had a problem! |
| | #3 |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| My friend ran a 11.1 lipo last weekend with no problem through his evx. He liked it. |
| | #4 |
| Quarry Creeper Join Date: Nov 2004 Location: Elkton/Newark
| The only problem that I see is that you're using LiPo's with the EVX. I don't know if anyone would second me on this, but I wouldn't try it without a voltage regulator or low battery alarm. Since the EVX doesn't have a voltage regulating/monitoring function, it might be possible to run the pack voltage low enough to cause internal damage to the cell/cells. |
| | #5 |
| I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| yes it is possible to over discarge a lipo with the evx. but lipo's are easy to tell when there done the voltage drops very fast so as long as you shutdown as soon as the voltage drops you are safe. just watch it very close |
| | #6 |
| I allready run a voltage reg. and I plan on adding a volt cutoff as well. I was mainly concerned with the output to the motor(s) I think I'll get some time Sat. to play around with it so I will let you know if it works or not. I had a few minutes last night to solder on some Deans plugs and try her out. Good news! No smoke Last edited by racerx; 08-11-2006 at 09:10 AM. Reason: update: |
| | #7 |
| RCC Addict Join Date: Apr 2006 Location: Brighton
| Rob, Let us know how those are working for ya. LiPO on my homebrew stick could be interesting Stan |
| | #8 |
| Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
| i run a car batt in mine. no problem yet. just its to dam BIG. |
| Thread Tools | |
| Display Modes | |
