Thread: Lathe motor question
Old 08-08-2006, 10:33 PM   #1
Default Lathe motor question
So i had a question about 45 and 55 turn lathe motors. i know these create incredible amount of tourque and are rated at 12 volts, but i was wondering what i should look for when buying a esc and batteries. i have team orion 7.2v 3000mah packs, and figure they would work on a txt-1 with either a 45 or 55 turn. but was uncertain about an esc. I really dont have the 120 bucks to spend on a novak, and was looking at the LRP Runner Revers Plus, mostly because its waterproof, small and rated down to 15 turns, would this work or will it suck, my budget is around 60 or 70 for a esc. any help will be appreciated . thanks guys
rcdude0909 is offline   Reply With Quote
Old 08-09-2006, 07:11 PM   #2
one motor, or two?
mrbig is offline   Reply With Quote
Old 08-09-2006, 09:57 PM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
TXT, so one motor.
It would work on the motor no problem. The BEC is 1.5 amps though, and 5 volt. You would need a RX pack to power your servo if you want power.
JohnRobHolmes is offline   Reply With Quote
Old 08-09-2006, 10:06 PM   #4
Highmark's Avatar
I would grab a Tekin Rebel 2.
You can pick them up on ebay for about $85 shipped and they have plenty of BEC for crawling.
Highmark is offline   Reply With Quote
Old 08-09-2006, 10:10 PM   #5
I have TR2's as well, for one dollar less
