| | #1 |
| Newbie Join Date: Jul 2006 Location: NOR*CAL.....Bay Area
| I installed a novak xrs reversible esc and an ace rc 202a reciever. the problem is when i turn on the esc the led stays lit, then when i press the setup button the led turns off. i then try again to get the setup started, but the light never goes to a solid red light to allow programing. |
| Sponsored Links | |
| | #2 |
| Rock Crawler ![]() Join Date: Jul 2006 Location: barstow
| are your reciever wires in the correct order. it could also just be a defect it does happen |
| | #3 |
| Rock Crawler Join Date: Jun 2006 Location: LOMPOC
| i also have the same problem with my xrs. the led stays red then turns off and doesn't turn back on. i have checked all the connections and tried charging my battery three different times so i know i have a charged pack and it still doesn't work. Last edited by CRAZYACE63; 08-14-2006 at 10:15 PM. |
| | #4 |
| Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
| Do you two still have the instructions to it. I run one and it has been very good to me. Even with 4WS. What rcjunky said. ESC should be in channel 2 on RX. |
| | #5 |
| Quarry Creeper Join Date: Jun 2006 Location: Pinckney
| You guys running new wiz-bang digital servos? |
| | #6 |
| Get off my lawn! ![]() Join Date: Feb 2005 Location: Cleveland, OH
| You have to hold the button for a couple seconds before the LED comes back on. |
| | #7 |
| I Have Just Some Standard Servos Right Now. I Have Tried To Hold The Button For At Least 30 To 40 Seconds With Out It Changing. Tried Turning The Esc Off Then Back On And Still No Luck. |
| Thread Tools | |
| Display Modes | |
