Thread: Can i use a rebel 2 esc to a clodbuster ??
Old 08-12-2006, 02:01 PM   #1
Default Can i use a rebel 2 esc to a clodbuster ??
http://www.rcpics.net/view_single.php?medid=79733
the esc have only connections for one engine but cloden have two engine pleace help my
theswed is offline   Reply With Quote
Old 08-12-2006, 02:05 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Yes, it will work just fine. You will need to make a jumper. Connect the ESC to the rear motor as you would normally, and then jumper the neg on the motor to the positive on the front motor. Also connect the positive on the rear motor to the neg on the front motor. This is so your motors spin the correct way (assuming the endbell has not been rotated on one of the motors)
JohnRobHolmes is offline   Reply With Quote
Old 08-12-2006, 02:23 PM   #3
thanks good but I dont know not what a juper is maybe you know where can get a picture or somting so i can se how to do it
Old 08-12-2006, 02:28 PM   #4
A jumper is just a wire. I will look for pics..
Old 08-12-2006, 02:29 PM   #5
This post may help you series or parallel
any why is the edit button not working again?
Old 08-12-2006, 02:36 PM   #6
nice tanks shall I use right or left on the picture
Old 08-12-2006, 02:38 PM   #7
parallel, so right side. What motors are you running?
Old 08-12-2006, 02:41 PM   #8
the orginal 540 motors
http://www2.towerhobbies.com/cgi-bin...?&I=LXGMR9&P=0
Old 08-12-2006, 02:43 PM   #9
Wire the front motor backwards, or your axle will spin the wrong way.
Old 08-12-2006, 02:58 PM   #10
ok thank for ure help
Old 08-12-2006, 04:08 PM   #11
I split the wires at just 2 inches out of the ESC. Uses a bit less wiring, less wiring = less resistance.
camel_rc is offline   Reply With Quote
Old 08-14-2006, 01:45 PM   #12
you men split the wires befor the first motor
Old 08-14-2006, 10:21 PM   #13
Correct. Instead of splitting at the motor, split it before the motor.
Old 08-15-2006, 08:53 AM   #14
ok Thank you for all help
soon is clodbuster completed for the first drive
