| | #1 |
| Newbie Join Date: Dec 2005 Location: UK
| I went my new LHS today for some wiring bits for my integy 55t, when i asked the guy behind the counter about deans connectors he looked at me like i was talking a foreign language |
| Sponsored Links | |
| | #2 |
| 1* ![]() Join Date: Dec 2005 Location: Ozarks
| I solder automotive spade connectors onto the esc motor leads. They fit perfectly on the motor tabs and allow you to switch motors without cutting the wires or getting out the soldering iron. |
| | #3 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| I solder mine directly. Never had any issues. Of course I have a 250 watt soldering iron so I can swap a motor in minutes. |
| | #4 |
| Cheers guys, nice idea rcr3fan thanks for the tip, Yeah franky iv also got s**t hot soldering equiptment at my disposal, il give it a try tomo thanks for your help :-) |
| | #5 |
| Pebble Pounder Join Date: Jul 2005 Location: Greece
| I always solder to the motor. One less connection to risk coming loose. Only takes a minute to solder two wires on. |
| | #6 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| I use deans plugs because it is fast. I can swap out any motor or esc in a flash. My brushed motors can all be plugged into a pack straight to drain them or break a motor in. Female plug on battery, male plug on motor. ESC is mated accordingly. But what am I talking about? I havent used brushed motors in quite some time, except in my servos |
| | #7 |
| Newbie Join Date: Jan 2006 Location: Redmond Oregon (High Desert)
| The connectors are for disconnecting the motor from the esc.It just makes it easier to work with.If your out in the field and your motor burns up and you soldered the leads together, how you going to get it apart to put your spare motor on? This is what I use on my three tlt's------ http://www2.towerhobbies.com/cgi-bin...&I=LXTJ21&P=ML |
| | #8 |
| RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
| i solder directly to the motor. but if i did use connectors instead, definetely use deans plugs. |
| | #9 |
| Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| For just my bashers and crawlers I have always used some 3M Female 1/4" Slide Connectors. If you are just bashing that would be ok. but If you are racing and need to disconnect the motor easily, solder direct to the motor and have some Deans plugs betwent the ESC and Motor. Deans plugs are suppose to have the same or less resistance than the same length of wire that would be in its place. |
| | #10 |
| Get off my lawn! ![]() Join Date: Feb 2005 Location: Cleveland, OH
| Yeah, the guy at the LHS is probably a hard-core racer who solders his batteries, too. For all the current a lathe motor draws, you could get by with just about any connector, or even twisting the wires together. I have Deans on my batteries and assorted motor connectors. Some are soldered, some use terminals. All the brushless motors have bullets, and even some of the brushed motors use brushless bullets. When you have 20+ cars & trucks it's hard to make the transition to brushless in one go, but I'm getting there slowly. 3/20+ with a new Novak Crawler on the way. |
| | #11 |
| Pebble Pounder Join Date: Jan 2006 Location: Canada
| I run Deans on all my cars/trucks on both the battery and the motor. Makes life a lot easier when swapping parts and Deans connectors are practically zero loss and never, ever come loose. |
| | #12 | |
Thanks for the opinions and experience everyone, much appreciated, | |
| | #13 |
| I am moving to all bullet plugs too Micro. I have not used my brushed motors enough to rewire them though. That would be a HUGE advantage over deans plugs though, you could reverse the motor rotation direction in a snap. The hard part is when you have 3.5, 4, and 5.5mm bullet plugs. Then you have to make adaptors or switch something out. |
| Thread Tools | |
| Display Modes | |
