| | #1 |
| Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
| ok i searched but does any one have a link or tips/pics on how to turn a futaba servo into an esc for a micro crawler??? help me, all i found was people who have done it !!!! |
| Sponsored Links | |
| | #2 |
| MWRCA'er ![]() Join Date: Apr 2004 Location: Byron, IL
| Do all of this and you will have a motor gearbox and esc all in one. Or pop the electronic guts out and resolder the motor leads to your new motor. http://www.badgerracing.com/~rcracer/winch.htm |
| | #3 | |
| RCC Addict Join Date: Mar 2005 Location: Saginaw
| | #4 |
| thanks guys so im guessing youre saying that you just solder motor connections to where the servo motor was powered. ? what about the limiter thing on the futaba servos can i just cut it off ? i would use the servo as a gear box but its a little too slow... |
| | #5 |
| | #6 |
| Newbie Join Date: Jan 2006 Location: kansas city
| still no real explanation about how to make an ESC out of the servo........ that is good info in the winch side of it...... i would like to know as well. thanks |
| | #7 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| turning the servo into a winch IS making the circuit board into an ESC of sorts. It will power a motor forwards or backwards as long as you keep the throttle on. |
| | #8 |
| Predator micro motors ![]() Join Date: Dec 2005 Location: houston
| Is it proportional, and how much can it handle as far as size of motor? |
| | #9 |
| Rock Crawler Join Date: Jun 2006 Location: Maryland
| WHY START A NEW THREAD, IF I CAN CONTINUE AN OLD ONE. I am looking to covert a servo board into a ESC, and the winch thing is a great Idea, but I dont think it is proportional. In order for it to be a true esc, It needs to be proportional. Bribeguy did it with his MICRO-JEEP, and in the build thread, he added some capacitors, but didnt go into detail on this. I am getting ready to do a 1/24 ssmt build, and I need to do this because I will be using a servo as a tranny, and want to use the circuit board as my esc. Thanks for any help!! -Brian |
| | #10 |
| Quarry Creeper Join Date: Jan 2007 Location: Ontario, Canada
| Step one: Take apart the servo and remove the board, potentiometer (pot) and motor. Step two: turn the pot all the way to the left, measure resistance between the middle lead and an outside lead (try both outside leads, you want the one that will give you the greatest resistance) Step three: find two 1/4 watt or greater resistors equal to roughly half the resistance you read from the pot. (Both resistors have to be the same value) Step four: unsolder pot from board. Step five: solder one lead from each resistor to where the middle pot lead went, then solder a lead from one resistor to where the right pot lead went and solder a lead from the other resistor to where the left pot lead went. Step six: Unsolder motor wires and leave as motor leads. That will power itself right of the receiver, you might need to mess with your trim a bit to find the neutral point. Its fully proportional in forward in reverse but it wont have brake and after you reach around 3/4 tx throttle it wont go any faster. Who says noobs know nothing? Last edited by HndsWthtShdws; 02-25-2007 at 05:12 PM. |
| | #11 |
| Fantastic HWS!!!! This forum could use more reply's like this. That is exactly what I was looking for. Thank you I will be hitting up the local radioshack to pick up some resistors tommorow, and report back with my results. Thanks again |
| | #12 |
| Np, you better post up some pics when your done the crawler. |
| | #13 |
| Will do! Its going to be a scale unimog. Look for a build thread in the near future. |
| | #14 |
| I did it. It works, and well I might add. It took a while to trim it out, but once I got it trimmed out it was nice and smooth. Thank you HndsWthtShdws, I appreciate it. I will post pics when I start the build thread. Thanks again! |
| | #15 |
| Newbie Join Date: Mar 2007 Location: Holland
| I'm trying to build a "nano" now also.. Starting with a ssmt. I'm new to rccrawler.com... I am not a novice to R/C by any means though.. This stuff just isn't normal.. lol.. Anyways, if you center the POT and glue it as indicated b4, will that make it proportional? Or on-off only in forward and reverse?? Please explai nmore.. I can't find info anywhere and I do not want to destruct a servo till I have the facts. |
| | #16 |
| If you center the pot and glue it it will still be proportional. |
| | #17 |
| I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| i read somewhere you can also solder in a couple of resistors in place of the pot, then you dont have to worry about centering it. |
| Thread Tools | |
| Display Modes | |
