| | #1 |
| Rock Crawler Join Date: Dec 2005 Location: Borderland Tejas
| I'm stumped. I have a TQ3 w/ rear steer mod from TCS and TR2. When I use the tq3 that came with the reciever on the truck everything works fine except for the front steering it backwards. If I use the tq3 from my FJ-40 build, then everything is fine. This is when you think that I just need to flip the switch on the channel for the front steering. Did that. I switched channels 1-3 on the front and no difference. I believe the front steering is on ch1. When I change ch1 there is no change in front/rear steering or throttle/reverse. Anyone have any ideas? Everything is brand new. |
| Sponsored Links | |
| | #2 |
| anyone |
| | #3 |
| Quarry Creeper Join Date: Apr 2006 Location: Norcal
| Flip your servo around? |
| | #4 |
| I thought of that but that is more of a bandaid fix. |
| | #5 |
| I wanna be Dave Join Date: Mar 2006 Location: One Legend.
| when you use your other TQ3 does flippng the switch reverse your steering? |
| | #6 |
| Nope. Almost makes me think when the reverse steer mod was done, something came loose at the back of the ch.1 switch. I can flip it back and forth all day long and nothing reverses. |
| | #7 |
| So neither TQ3 reverses the channel for your steering? I find it hard to believe you have 2 bad TQ3's... Does it work to reverse it on your other truck? |
| | #8 |
| No, my original TQ3 works fine, its the 2nd one that the front steering won't reverse. |
| | #9 |
| ok, that makes sense then. Looks lik you just have a bad TQ or like you said something came loose. |
| | #10 |
| TCS rocks, Kevin is going to take care of it :-P Apears to be a loose connection in the controller. |
| Thread Tools | |
| Display Modes | |
