Thread: Need Help PLEASE!
Old 10-12-2012, 05:07 PM   #1
Default Need Help PLEASE!
Ok I have a traxxas tq 2.4ghz 4 channel controller, a rc4wd bulldog 9300xt winch. I would like to make the 4th channel middle position a so called dead spot. so when i hook the winch up it does not move in that middle position. what do i have to do to make that happen. any help would be appreciated.
jeepd77 is offline   Reply With Quote
Old 10-12-2012, 06:31 PM   #2
Default Re: Need Help PLEASE!
Is it a 3 position channel with 3 position switch?
SMR 510RR is offline   Reply With Quote
Old 10-13-2012, 12:29 PM   #3
no its a 4 position channel with 3 position switch.
Old 11-12-2012, 05:54 PM   #4
after thinking about this for a while, i believe you are right. it is a 3 position channel but its the fourth channel on the traxxas tq2.4 4channel radio. however it is a 3 position switch. any help would be greatly appreciated
Old 11-12-2012, 06:24 PM   #5
3 pos is already ready to go if thats what the 4th ch is on the traxxas remote....plug it in and go...there is a lil flathead screw on the winch controller to center it if it is moving on you when you plug in and power up
greggreg2011 is offline   Reply With Quote
Old 11-12-2012, 06:39 PM   #6
after a quick search the 4th ch on the tx is not a 3pos switch, it seems it can be modded to a true 3 pos switch or you can buy a controller to work with whatever the 4th ch is on there.
hope it helps. google search traxxas 2.4g 4ch as a winch and you shall find the info
Old 11-12-2012, 07:09 PM   #7
If it's a 2 position switch, contact HeyOK (possibly LosiKid as well) on an adaptor that will work with a 2 position switch.
Both are here on RCC as vendors.
Charlie-III is offline   Reply With Quote
Old 11-13-2012, 02:13 AM   #8
For some reason the 9300 stock controller don't have the dead spot even with a 3 position switch. It will drift no matter how you adjust the center position. Mine changed to hayok winch controller cured the winch drift problem. FYI.
Camasrider is offline   Reply With Quote
