Thread: winch problem
Old 08-16-2006, 11:24 PM   #1
snook's Avatar
Default winch problem
hey guys i have a mini t battery pack, 3 way switch, and a 645mg servo is there any way i could wire this all up to make a winch?Click the image to open in full size.
snook is offline   Reply With Quote
Old 08-16-2006, 11:39 PM   #2
MWRCA'er
Mnster's Avatar
Yes take all of the electronic guts out of the servo except the motor. Then use some wire hook up your 3way switch and battery pack to the servos motor. I have ran a setup just like that before. The manual switch on the truck sucks though. The truck starts winching away without control. When the truck is near the end of the line you have to be quick to shut it off before the line reels in and snaps off.
I'd mount the switch in a TQ3 radio and find a esc to power the winch. The stock servo control unit does not have enough power to really pull like you need it to.
Mnster is offline   Reply With Quote
Old 08-16-2006, 11:55 PM   #3
snook's Avatar
thanxClick the image to open in full size.
Old 08-17-2006, 12:04 AM   #4
snook's Avatar
one more ? i did that but do i pull the motor off the chip and wire it to the 3 way switch that way or leave it on the chip?Click the image to open in full size.
Old 08-17-2006, 01:25 AM   #5
MWRCA'er
Mnster's Avatar
