Thread: New way to turn big tires
Old 08-17-2006, 02:08 AM   #1
Default New way to turn big tires
I have seen it done and know it works great.. so I guess it is not totally new, but could be to some
anyways
1/5scale servo with a 333oz-inch rating.... WOOT!!! FELL THE POWER
http://www2.towerhobbies.com/cgi-bin...?&I=LXLWS8&P=0
anyone see any reason why everyone is not doing this?
look at the price
333 oz-inch for $40
or u could get a $100+ hi-tech that does maybe 200oz-inch...
COMMENTS???
Jeepernick is offline   Reply With Quote
Old 08-17-2006, 02:22 AM   #2
yeah thats a good price but i bet there fawkin huge
Got Rocks? is offline   Reply With Quote
Old 08-17-2006, 02:24 AM   #3
yup
problem?
Old 08-17-2006, 02:26 AM   #4
Size- 2.6 x 1.18 x 2.25 in. (66x30x57mm)
Weight- 128g (4.52oz)
big deal 4.52oz added to ur rig... when that is still the lightest thing really...kinda
the size.... mounting maybe a issue... I'll find a way
Clod axles are big enough to mount one of these on, right?
Old 08-17-2006, 03:04 AM   #5
Prick
rambuller84's Avatar
I've got a "Large scale" Hobbico on my TXT. I can put it in a persons hand, have them grab the servo horn and turn the wheel and even my big azz uncle can't keep it from turning. They'll start breaking shiat real quick if you aren't careful though
rambuller84 is online now   Reply With Quote
Old 08-17-2006, 08:31 AM   #6
The 100 dollar Hitec ones get about 333oz's at 6v. I was running them for a little while. They worked great.
mrwonderful is offline   Reply With Quote
Old 08-17-2006, 08:46 AM   #7
Originally Posted by Jeepernick
1/5scale servo with a 333oz-inch rating.... WOOT!!! FELL THE ....
....ARMS SNAP!
FrankyRizzo is offline   Reply With Quote
Old 08-17-2006, 08:55 AM   #8
Pretty much the Same Servo just cheaper.
http://www2.towerhobbies.com/cgi-bin...0&I=LXLN93&P=K
Old 08-17-2006, 09:13 AM   #9
WOOT!!! FEEL THE...
battery drain faster than ever before!
Unholy is offline   Reply With Quote
Old 08-17-2006, 09:26 AM   #10
Picky Fab'r/Acetal Junky
Offroader5's Avatar
I picked up some 1/4 scale Hi-Tec's that I was going to use, and even with a 3/4" widener/adapter on the wheel, the servo won't fit on the axle stay between the gear housing and the inner sidewall of the tire without having the tire rub constantly against the servo body. If you mount it vertically on the axle stay it would work, but then you have that 2.6" sticking straight up off the axle.....
If your in the market for large scale servos...I have 2 Hi-Tec HS-755MG's I will sell you real cheap. They are 200 oz @ 6v. and metal geared. PM me if interested.
Offroader5 is offline   Reply With Quote
Old 08-17-2006, 10:29 AM   #11
I run 2 hitec 805 bb's 1/4 scales(same as hobbico cs-80) on my clod and allways have and LOVE them they are just big I started out over volting them with 7.2 and they would last 3 or 4 comps and burn up but since I started to run them on 6 volts I havent had any issues at all.They are allmost inpossible to break Me and heavy both have only broke one a peice and that was falls down hill on the vose to snap the servo horn off right at the case.
syco133 is offline   Reply With Quote
Old 08-17-2006, 12:20 PM   #12
sounds like they work and people use them... like i said I knew some of u did just wanted comments
so u would recommend getting alum. hubs on my future clod axles before running one... any thing else it is hard on?
Thanks for all the comments guys
Old 08-17-2006, 12:38 PM   #13
I have already made a topic for this servo and one of the answer is very interesting :
Originally Posted by trevorsride
Yes they do have plastic gears. I run the 3306 in my 1/5th scale HPI baha 5B. I have gone through 5 sets of gears in the Baha in about 5 months. HPI also sells the same servo relabled as a HPI SFL-10. HPI will have metal gears out for them by next month. I do believe that it is a little larger in size than most 1/5th scale servo's, so may not be a good option for our crawlers.
Link to my topic: Anyone try Futaba S3306 (1/5 scale servo) ?
Personnaly, I will probably buy CS-80.
Benlatak is offline   Reply With Quote
Old 08-17-2006, 12:55 PM   #14
Cool thanks, I searched for 1/5 scale servos and for 1/4 but didnt come up with anything useful
I will read that
THanks
