Thread: Radio/ESC settings - End Point adjustments
Old 08-17-2006, 05:30 PM   #1
Question Radio/ESC settings - End Point adjustments
Fellas, on your EPA settings (End point/travel adjustments), what settings are you using for the throttle ? Since speed is not a factor, do you still need to set it up to 100 % or higher, or can you just set it lower, say 70-80 percent ?
Thanks, Mark
Marcusg is offline   Reply With Quote
Old 08-17-2006, 05:36 PM   #2
K_B
I would think it's a matter of personal preference. I max out my throttle end points so that I use the motor to it's max potential. I use gearing to dictate top speed/torque.
K_B is offline   Reply With Quote
Old 08-18-2006, 12:07 AM   #3
Moderator
RXcrawler's Avatar
What he said
RXcrawler is offline   Reply With Quote
