11-09-2012, 02:44 AM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Home
| RC4WD mayhem high torque servo problem
Hey I have a mayhem high torque, $30 one that is now discontinued, in my TF2 for the shifting and it gets incredibly hot. I only used it one time with out the body on, as it is not finished, and when I stopped I could feel heat. I panic'd at first thinking it was my ESC or motor... But no it was the mayhem high torque shifter servo. I have the servo plugged into the AUX on my receiver, sr300 with dx3s. I had change gear a few times but I wouldn't think that would make the servo get that hot. Any body have the same issue, or am I being a newb again? |
11-09-2012, 09:14 AM | #2 |
It sounds like your epa is off causing the servo to try and push the linkage further than it can causing the extra heat Sent from my SCH-R530U using Tapatalk 2 |
11-09-2012, 10:35 AM | #3 | |
Newbie Join Date: Nov 2012 Location: Wilmington
| Re: RC4WD mayhem high torque servo problem Quote:
^^^Agree on both accounts, trim the "xtra" out with the endpoint adjustment. Should "push" past your steering/gear selection max. | |
11-09-2012, 05:50 PM | #4 |
I should have known that, thank you.
11-10-2012, 01:56 AM | #5 |
Newbie Join Date: Mar 2011 Location: bismarck
if you dont have a computer radio try moving to a shorter hole on the servo arm to reduce the throw
RC4WD mayhem high torque servo problem - Similar Threads | ||||
High torque servo | toni | General Crawlers | 6 | 06-09-2011 08:58 AM |
