11-10-2012, 11:33 AM | #1 |
Rock Stacker Join Date: Aug 2012 Location: Grand Junction
| Mamba Max not turning Motor
Just got a Mamba Max Pro for my Wraith hooked it up with a CC BEC and did the start up programing. I have a Novak 45T and it will not turn it just shutters. It did try one time to run but just for a second. No binding hooked battery straight to motor and it worked. Thanks for any help |
11-10-2012, 12:03 PM | #2 |
| Re: Mamba Max not turning Motor
"Start-up programming", you mean a RX/ESC calibration?? That would be step-1. If you did the calibration, was the TX throttle EPA's set to 100%, trim & sub-trim to "0"? Direct connect to a known good battery pack is a GREAT way to test the motor. Congrats as it rules out some things. Is the radio (TX & RX) known to be good? |
11-10-2012, 12:09 PM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: martins ferry
I bet it is setup for brushless, you just need to program it for brushed motors easiest is with castle link but can be done with your transmitter. Sent from my DROID RAZR using Tapatalk 2 |
11-10-2012, 01:12 PM | #4 | |
Rock Crawler Join Date: Jun 2009 Location: summertown
| Re: Mamba Max not turning Motor Quote:
X2 sounds like its still setup for smartsense brushless. program it to brushed and youll be good to go. | |
11-10-2012, 09:48 PM | #5 |
Rock Stacker Join Date: Oct 2012 Location: Yakima
Your LHS should have a Castle Link they can whore out to you...
11-11-2012, 04:46 AM | #6 | |
If you try to run a regular motor on that setting it can destroy the ESC! For some unknown reason Castle doesn't provide a warning about this issue! I got the warning in time and made double sure my ESC was set for brushed motors before hooking it up to the motor. | |
11-11-2012, 10:20 PM | #7 | |
edit: just went out and looked at the little quick start up guide...it's mentioned TWICE. Once that the default setting is brushless, and once that if you are going to use a brushed motor that you need to refer to the programming guide to set it up properly. Last edited by Duuuuuuuude; 11-11-2012 at 10:29 PM. | |
11-12-2012, 04:47 PM | #8 | |
Page 2, general warnings: No mentioning that the ESC might brew if you try to run a brushed motor in brushless mode. Page 3, quick start: Assumes using a brushless motor. Any half-whit with a brushed motor will attach it correctly (as described on page 10) and do the calibration by the book before adjusting the programming to brushed mode. After all it clearly tells you to do the calibration first, and without a Castle Link adapter it's the way to do it! Page 6-8, General description: "Most users may simply plug the controller into their motor... and run it immediately." Not a single word about changing the programming for proper motor type. Pages 10-11, Brushed motor wiring: Not a word about checking/changing the programming, or that failing to do so before attaching the motor can cause problems. Only that the wires might be swapped to get the motor running in the right direction after calibration. Pages 13-16, ESC calibration: Lots of warnings about battery polarity, but at the end it says you can use the ESC immediately after calibration. The text writer assume the user has a BL motor and makes no mentioning of any differences if you don't... Page 35, manual programming, motor type: 1. Brushless, says it's the default setting but no caution what will happen is you use it with a brushed motor. 2. and 3. Brushed motor settings, likewise no mentioning of what can happen if you try to run a BL in this mode. This is the only place in the entire manual where it actually says it's even possible to change the motor setting! Given that editing the program is described (on page 6) as something for "advanced users", one can easily assume that "basic" users will skip the entire chapter about manual programming. Pages 37-40, troubleshooting: No mentioning of the possibility to forget changing the motor type setting. ________________ Thus I stand by my previous claim: No mentioning that the MMP is likely to take permanent damage if you try to run a brushed motor with the default settings! And only in the chapter you're not expected to read until after doing some bit of driving are you told to change the motor type... ________________ Now for the Quick Start Guide that I think you're referring to: I agree that it does say that sensorless brushless mode is the default setting... ... but the entire guide is about sensored vs sensorless BL motors. No mentioning that the default setting is not good for brushed motors! No mentioning of brushed motors at all! It just says that the default setting isn't the best for sensored BL motors... | |
11-12-2012, 05:03 PM | #9 |
How about page 1 where it says "Instruction Manual for all Castle Creations Car and Truck Brushless Power Systems"? That would be a clue that you might have to do something before running a brushed motor... Page 2 mentions that it is a very powerful brushless motor system. Yet another clue... Page 3 mentions connecting the 3 wires to the motor...yet brushed motors only use 2...hmmm I'm starting to see a pattern here... Page 5 shows the table of contents and lists what page you can find the instructions to change the motor type. Gee, I wonder if they mean changing it to brushed... If you haven't figured out by this point that you maybe just might have to program it to run brushed...you're probably a big fan of lead paint sandwiches. Page 6 recommends you read the entire manual, but who has time for that? You can stand by whatever you want, but don't blame Castle for your failure to read instructions, which they do recommend you do. Also, "most' people does not mean "all" people. |
11-12-2012, 05:15 PM | #10 | |
So I guess that is a big nanny nanny boo boo to you, sir. | |
11-12-2012, 07:16 PM | #11 |
OK, I guess we all agree that CC SHOULD revise their manual. Then again, if a user only reads part of the manual, they WILL miss relevant parts. Yes, yes, yes, I know, "Real men don't read instructions". But, you WILL get hung if you don't read them even if the relevant bits are many pages beyond where you stopped reading. PS, I have similar discussions with my own office regarding manuals...... |
11-12-2012, 07:24 PM | #12 |
I read instruction manuals all the time, even on things I am familiar with. Revisions are made, design changes are made, features are added. Better to not be cool and read than be cool and be out a few hundred (or thousand) dollars. |
11-13-2012, 02:34 PM | #13 | ||||
I'll get back to this below... ... only if you want to get the most from the ESC. (Not specifically recommended just to get going.) At the top of page 6 it's already been stated that the default settings should be fine to get you running. No, some feel they really "need" to get the most out of their ESC. Those are the ones that are recommended to read the entire manual and change the programming. Quote:
My main issue is that if you follow the written instructions in an attempt to quickly get the motor running you will fail. There's no indication that you need to alter the programming (and thus read that chapter of the manual)! To me that's a clear indication that the motor type by default is sensed automatically (just like the default battery settings sense (LiPo) battery cell count). Automatic motor type selection is no technical difficulty to implement: - During start-up of the ESC first measure the resistance in motor lead pairs A-B and B-C. - If those pairs have no connection there's either no motor attached or a (reversing) brushed motor. - If those pairs are connected with some resistance it's a brushless motor, with somewhat high wind count. - If those pairs are practically shorted, measure the voltage on the motor leads. If it's 0V it's a brushless motor, if it's the battery voltage it's a (high power) brushed motor. Now, since there is no default automatic motor type sensing the instructions how to attach a brushed motor should clearly state that a programming change is mandatory! | ||||
11-13-2012, 02:46 PM | #14 |
Not per say? Seriously? If you bought a part that will fit on a Ford but the instructions keep saying "Chevrolet", you wouldn't read on until you found the part that says "for Ford users"? Still, if you can't deduce after reading just a page or two that you might have to do something special to run a brushed motor when all that they are talking about is brushless, you're pretty dense. Castle makes brushless motors and brushless escs. Their products by nature are geared toward brushless users. Part of "getting the most" out of it is making it work with a brushed motor. Keep arguing your point. You're getting really creative and I must admit, it is entertaining. Though I will agree that the warning way in the back should be right up front. |
11-14-2012, 12:47 AM | #15 | ||||
That's all the deviation implied by the manual's general use of the term "brushless". Quote:
So, why should the user think that the motor type isn't by default set automatically into something that's if not optimal so at least functional and safe? (If you attach a sensored brushless motor it will run, but not utilize the sensor.) Quote:
I'd say that to most users there's a definite difference between getting the most and getting something (other than smoke). | ||||
11-14-2012, 01:56 AM | #16 |
I wanna be Dave Join Date: Jun 2007 Location: Arlington wa
Castle link is your friend.. with the click of a mouse all is well... |
Mamba Max not turning Motor - Similar Threads | ||||
Mamba Max Pro - What motor? | LivDoug | Axial AX-10 Scorpion | 14 | 04-29-2010 01:41 PM |
Mamba Max and What Motor? | sdriza | Team Losi Comp Crawler | 11 | 06-26-2009 01:50 PM |
Mamba Max steering but no motor | tedmales | Electronics | 3 | 08-28-2008 09:13 PM |
