08-30-2006, 12:43 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: Gervais
| moped problems
Im running a 1500ahm pack and a tq3 reciever with a 20 turm moter. I tried to set the moped but it doesnt work . when i turn it on the moter doesnt move like its supposed to. It moves when I turn it off:-( . The light wont go off when I press the set button. The steering works. What should I do?
08-30-2006, 12:48 PM | #2 |
is it hooked up to ch2 on your receiver, i was in such a rush myself that i had hooked up mine on the batt slot , check your connection first.
08-30-2006, 01:05 PM | #3 |
It is on the second. Are the wires black to black on the moter? but before I did that I moved the throttle stick to see where to plug it in before I set it. with the thing on. at first the moter did move when I turnd it on. now it doesnt. I never pressed the set button. Did I break it? Last edited by revoster; 08-30-2006 at 01:25 PM. |
08-30-2006, 01:50 PM | #4 |
no, try resetting it, also see if you plugged in backwards in the 2 slot.
08-30-2006, 01:52 PM | #5 |
How do you reset it?
08-30-2006, 01:56 PM | #6 |
follow the same instructions for initial set up
08-30-2006, 01:56 PM | #7 |
Rock Stacker Join Date: Aug 2006 Location: Co. Durham U.K
Just set the neutral, full and reverse like you should have done when you first set it.
08-30-2006, 01:59 PM | #8 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
I've had the same problem and did the reset thing but it won't reset. Light just stays on. I'd also like to have some help on this. |
08-30-2006, 02:23 PM | #9 |
I have the same problem as double j. The light wont go off when I press the button. Is it returnable still?
08-30-2006, 02:52 PM | #10 |
guys i had one of my mopeds do that, i did reset like 4-5 times until it worked, the only other one that failed on me just went up in smoke but it was a lousy connection on my part.
08-30-2006, 03:07 PM | #11 |
How hard do you have to press the button?
08-30-2006, 03:09 PM | #12 |
it's a micro switch so it shouldn't be to hard unless it's defective , try pressing it a little more firm, don't know what else to say sorry.
08-30-2006, 03:22 PM | #13 |
I was pressing it kinda hard is that bad?
08-30-2006, 03:23 PM | #14 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
is the button coming back up?
08-30-2006, 03:28 PM | #15 |
i cant tell. It doesnt do any thing when I press the button but goes down a tiny bit. It keeps doing that so I would say yes. And when I turn it off the moter moves. but not when I turn it on.
08-30-2006, 04:33 PM | #16 |
Wow I got it to work. but the on/off switch doesnt turn the light off. Is that normal?
08-30-2006, 04:34 PM | #17 |
That happens to quite a few ESC when the battery is low...
08-30-2006, 04:39 PM | #18 |
In that case how long should I charge a 1500 somethin pack on quick charge. Untill warm? also my moter is running real weak and making dinging sound. When I set it up(finnaly) it worked and went really fast. What is it?
08-30-2006, 09:26 PM | #19 |
Well now my battery is fully charged but the moter still wont turn fast. When I turn it on the moter doesnt mov like its supposed to ,or move a tad bit, or jump move fast and I see a flash of light. The moter turns very weakly. And when I press the set button the moter doesnt turn like its suppoesd to. What is wrong?
08-30-2006, 09:28 PM | #20 |
Sounds like you may have a bad unit, that sucks!
