Thread: ***Trinity Epic D3 21.5 shaft size?***
Old 01-24-2013, 09:59 AM   #1
Question ***Trinity Epic D3 21.5 shaft size?***
I just got a Trinity Epic D3 21.5 motor as part of a package deal and I want to get a pinion gear set but I am not sure what bore size I need.
Does anybody know what pinion bore size is needed for this motor?
Joe226 is offline   Reply With Quote
Old 01-24-2013, 01:14 PM   #2
Should be the standard pinion size for all 540 electric motors which is 3.?? mm don't remember exact size
Sent from my SCH-R530U using Tapatalk 2
benoj is offline   Reply With Quote
Old 01-24-2013, 08:14 PM   #3
Default Re: ***Trinity Epic D3 21.5 shaft size?***
I tried pinion gears that fit a Novak Crawler 21.5 (look to be 3.5mm, but not sure) and they are a little too small.
Old 01-25-2013, 10:55 AM   #4
1/8" or 3.17mm standard shaft.
SuperRoo is offline   Reply With Quote
***Trinity Epic D3 21.5 shaft size?*** - Similar Threads
540 shaft size bahogtubig Redcat Crawlers 1 01-27-2011 07:57 PM
Output shaft size? Rudukai13 Axial AX-10 Scorpion 2 10-04-2007 03:53 PM
Shaft size on the GD600? jwrape General Crawlers 29 10-19-2006 06:28 AM
