09-01-2006, 10:53 PM | #1 |
| dynamite tazer is a pos, TR2 took a ****, now this super rooster is pissing me off
ok so the saga of my tlt continues, i just installed my super rooster last night, (well rizzo installed it i drank beer) but anyway its got a super rooster now... problem: its really smooth going in reverse, accurate, easy to control etc, runs great in reverse.. but its VERY touchy going forward, look at the trigger wrong and the truck jumps forward about a foot... im getting really pissed off no this is the 3rd esc ive installed in this ****ing thing and its still performing like ****... [rant off] but i must say when it does do what i want it to it crawls very well... any help would be great... |
09-01-2006, 11:00 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Three things to check: 1: Make sure you set it up for the transmitter your using 2: Make certain the speed control and your trims arn't reversed 3: Maybe your glitching? |
09-01-2006, 11:13 PM | #3 |
damn i have a lot to learn. i have no idea what 1 and 2 are... and its not glitching that was another problem ive solved already. its just way too touchy going foreward and its nice and smooth in reverse...
09-01-2006, 11:36 PM | #4 |
Check your motor, the brushes might be worn or binding
09-01-2006, 11:58 PM | #5 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
what radio do you have?
09-02-2006, 12:04 AM | #6 |
the motor might be possible, its used... ive got a JR xr3
09-02-2006, 12:08 AM | #7 |
make sure you dont have your exponitals set goofy iit would cause it to jump like that. I use them on my r1 to dumb down the throttle keeps me off the gas lol
09-02-2006, 12:18 AM | #8 |
ok cool, now i just need to find out what the heck those are... im gonna see if i can download a manual for my radio...
09-02-2006, 12:24 AM | #9 |
here you go xr3i http://www.horizonhobby.com/ProdInfo...342-manual.pdf xr3 old version the boxy one http://www.horizonhobby.com/Products...odId=JRP314127 Last edited by slobin3d; 09-02-2006 at 12:27 AM. |
09-02-2006, 12:25 AM | #10 |
yoou may want to erase your programming if your having probs its the easy way |
09-02-2006, 12:46 AM | #11 |
yeah ive got the older one, ima check out the manual in a minuite and figure out how to reset the thing.
09-02-2006, 01:00 AM | #12 |
well i cleared everything then i had the set the throttle trim all the way up to get the thing to sit still... i started adjusting things and it seemed to be getting better, but then the batteries on the radio started dying... so ill figure it out tomorrow.
09-02-2006, 01:48 AM | #13 |
well i got bored and decided to start messing with it some more... i got it to smoothen out a lot but its still a little jumpy and glitchy going forward. almost like the motor is dying, its smooth going in reverse but when crawling really slow forward it pulses like the motor is having a hard time turning... is this a possibility with my integy 55t lathe? it isnt new, i got it used. maybe i should get a new one....
09-02-2006, 04:27 AM | #14 |
Rock Stacker Join Date: Jun 2006 Location: Harlem
Try reversing the throttle in the radio and then swap the wires going to the motor.It sounds like when you are going forward it is using reverse in the speed controller.Forward should engage smoother than reverse,so I think you have it reversed. Switch the throttle in the radio and then see if it will engage smoother when going forward with the radio.(Truck should go in reverse)If it does swap the wires on the motor. |
09-02-2006, 07:58 AM | #15 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Bring it over today and I will look at it. BTW I ran that motor in mine and had no problem. |
09-02-2006, 01:40 PM | #16 |
well i guess its back to Dr. Rizzo for my TLT... this is horrible, i had better luck with my txt and its stock electronics, at least that thing ran.
09-02-2006, 01:43 PM | #17 |
once you reprogram the radio you will probably want to reprogram the ESC as well cause the siginal it is getting is going to be very differnt and it it was set with exponitials set its going to be way off too
09-03-2006, 12:08 AM | #18 |
i did that, its still jumpy as hell in forward and half the time it wont sit still, half the time it will... i had the chase the damn thing across my frontyard today.... **** it ill just put a brushless setup in it and get a new radio and RX... replace everything, that should fix it.
09-03-2006, 12:17 AM | #19 |
get the new dx 2.0 or 3.0 lol
09-03-2006, 01:12 AM | #20 |
yep i was already looking at them... revolver/quark or mamba and a dx 3.0...
