09-02-2006, 08:57 PM | #1 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| Initial Mamba Maxx setup
step B: Quote:
full reverse ? part reverse? | |
09-02-2006, 10:17 PM | #2 |
1: Full throttle 2: full brake 3: neutral. Once it sees all 3 points, you'll get the light-show, and it'll be good to go, or program with the Castle Link. |
09-02-2006, 10:18 PM | #3 | |
also using the spektrum I cant get past the initial setup full throttle ok but wont react to full brake/reverse any suggestions | |
09-02-2006, 10:27 PM | #4 |
Spektrum takes a while to establish its link to the receiver, and while it's doing that, your speedo is searching for a signal from the receiver. Which it can't get because the Spektrum hasn't booted up yet. I don't know if there's a way around that or not. YGPM |
09-02-2006, 11:02 PM | #5 |
Well by installing the nea firmware 1.07 I was able to get the intial setup to take.....after 40 trys I have the settings at: forward 100% reverse 100% brakes at 90% punch control 10% start power low motor timing normal drag brake 80% |
09-02-2006, 11:03 PM | #6 |
Isn't technology fun! |
09-02-2006, 11:17 PM | #7 | |
much better than the mamba 25 will try setting of from: forward 100% reverse 100% brakes at 90% punch control 10% start power low motor timing normal drag brake 80% to: forward 100% reverse 100% brakes at 90% punch control 0% start power medium motor timing normal drag brake 80% in the morning is this thing supposed to smell like burnt plastic on its first run? | |
09-03-2006, 07:21 AM | #8 |
I bet you could use a regular radio (like the TQ3) to get the initial set up to take. Then switch over to the Spektrum radio.
09-03-2006, 08:14 AM | #9 | |
09-03-2006, 08:19 AM | #10 |
Still smell like burning plastic? Definately 0 punch control. |
09-03-2006, 08:29 AM | #11 | |
