09-04-2006, 04:25 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| TQ3 mod + Radio Shack
I didn't want to use the normal On Off On Toggle to mod my TQ3 and started looking through radio shack for the parts. After going through about 4 different set up I found on that works. It doesn't have the return to center that would be nice but it works for the rear proportional steering. I'll post some pics later for a visual but do the mod as normal for rear steer but use a 5K - Ohm Audio-Taper Potentiometer. Radio Shack #271-1720. You'll have to cut the turning post because it's like 1 1/2" long. Specs on the part and it only costs $2.99. Resistance: 5K ohms + 20% tolerance Rated Power: .25 watts Sliding Noise: <47mV Total Rotation: 300 degrees + 5degrees Mounting Hole: 5/16" (8.2mm) The others I tried either didn't work or went straight from left to right with no centering available. I used a stock TLT 24t Spur for the steering wheel that works just perfectly in my hand. Again pics tomorrow. Have to go to work. :-( |
09-04-2006, 07:46 PM | #2 |
Quarry Creeper Join Date: Mar 2006 Location: Scappoose, OR
i have an old tq radio i've taken the steering wheel out of and am currently modding up for my rear steer |
09-05-2006, 09:00 AM | #3 |
here is the pics of the rear steer I did. As I said before you do the same mod as the other just add this part instead of the toggle switch. Modding it. fitting it in. Done and a few more shots. I hate the flash sometimes. Thats it hope it helps. jj |
09-05-2006, 09:22 PM | #4 |
here is mine. and its self centering |
01-06-2007, 01:11 AM | #5 |
Newbie Join Date: Nov 2006 Location: RedRock near BedRock
Thanks for heads up did the same mod to mine.....works beeeechin! |
11-18-2007, 12:24 PM | #6 |
Newbie Join Date: Oct 2007 Location: San Antonio
how do you make it self centering?
