09-05-2006, 05:34 PM | #1 |
Newbie Join Date: Jul 2006 Location: Canada
| 1/4 scale servo saver??
Anyone know of a servo saver that will fit the hitec 805bb / hobbico cs-80 / tower hobbies ts-80? I keep breaking the main servo gear on my txt's because I just run a horn. Thanks in advance.
09-07-2006, 08:49 PM | #2 |
| bump
bump
09-08-2006, 12:44 AM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Don't think so, You may be able to rig up some steering that gives. You know like flexable plastic links or something. Is the reason you are breaking the outputs do to, smashing the truck into rocks? If it is then you need to make a shield. Is the steering link mounted at a high point of stress like on the outside of the horn? Switch the link so its behind the horn. Hitecs are rumored to have stronger gears if that helps. They have the tougher grade Karbonite gears. |
