02-17-2013, 10:07 AM | #1 |
Newbie Join Date: Feb 2013 Location: Maine
| Super Brain 977
Another quick question.....What settings are appropriate for a 4.8v 220mah Nihm battery? The equipment was given to me from my brother so im not sure how to use it.....i dont even think he knew how to use it lol. |
02-17-2013, 01:38 PM | #2 |
| Re: Super Brain 977
settings for what?
02-17-2013, 03:11 PM | #3 |
| Re: Super Brain 977
Im currently at work I think what it asks for: Cell count- which i know is 4 Amps- I have no clue (guessing this is the rate i will charge at?) Mv(or Ma)- I have no clue (how the battery is detected finish charging?) if i could get some help with correct inputs for these provisions that would be great. |
02-17-2013, 03:31 PM | #4 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Re: Super Brain 977
I would charge it at 0.2 amps and the charger should auto detect when the battery is charged. If not discharge the battery completely and set it to 220mah
02-17-2013, 04:08 PM | #5 |
| Re: Super Brain 977
Most newer chargers want to know: Cell count Battery chemistry Mah From there they figure out when to shut down. In general, if they ask for a "charge rate", use "1C" which is the Mah/1000. Thus a 5500mah pack charges @ 5.5A for "1C", a 220mah pack charges @ .2A for "1C". They should charge in ~1 hour (if run to a reasonable LVC) unless they are out of balance. Yes, you can charge at higher amp rates, but everytime you do you run the added risk of shortening the life of the pack. For LiPO, you should almost ALWAYS balance charge (except for a 1S pack....). |
02-17-2013, 04:15 PM | #6 |
| Re: Super Brain 977
Great! thanks guys!.......should upon arrival of my new batteries drain them all till the truck no longer moves? and then re-charge.......i will have 3 of the 4.8v 220's.....is it necessary to let a battery rest after a complete discharge?......only reason im asking is because i have been flying micro helis for a bit and those require a cool down between charges..... like this: charge/cool/play/cool/charge is this same method necessary? |
02-17-2013, 07:26 PM | #7 | |
| Re: Super Brain 977 Quote:
If they get warm when in use, letting them sit a few minutes is good before charging. I never let them cool before use after charging. | |
02-17-2013, 07:42 PM | #8 |
| Re: Super Brain 977
Charlie, thanks for the drain clarification and charge recommendations. Much appreciated! |
Super Brain 977 - Similar Threads | ||||
Super Brain 977 | section525 | Electronics | 12 | 10-13-2008 02:43 PM |
duratrax ice vs. mrc 977 super brain | TIMZKRAWLER | Electronics | 7 | 09-22-2007 12:50 PM |
Super Brain 977 vs. Dynamite Peak Vision Ultra | K_B | Electronics | 5 | 04-20-2006 05:55 PM |
maybe a fix for super brain.... | eric113 | Electronics | 0 | 10-14-2005 06:46 AM |
