09-06-2006, 10:46 PM | #1 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
| Need wiring help...NOW!!!!!
Due to money constraints, i only recently was able to get all of the electronics for my comp rig for moab. Heres a list of what i got and then i'll tell ya the problem. Clod axles 2 65T lathe motors wired in series Novak XR wired for single battery use Spektrum DX3 venom 3000 maH pack 2 Hitec HS5694MG high torque servos heres my problem..... this thing is a turd! full throttle is bearly moving and the battery is daining REALLY fast! runtime is only @ 2-3 min. The ESC is not getting hot at all and periodically the rear motor has no power in reverse... will not move even when lifted off of the ground. So my questions are: Are the 65T lathe motors set to 0 (zero) degrees? Should i have this stupid thing wired in Parallel? Im going to try to re-wire by tomarrow night to check for wiring problems, if i cant get this thing working... i kinda have no reason to go to moab so any and all help is WELL appreciated... so .....HELP!!!!! |
09-06-2006, 10:49 PM | #2 |
Definately parallel. You sure the batteries are getting a full charge? |
09-06-2006, 10:49 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
you need to go parallel! here is a link- http://www.utrcrc.com/tech.html you can double check to make sure your motors are set to the zero degree timing mark. if this continues to be a problem, i'm sure between all of us at moab we will be able to get your rig squared away. |
09-06-2006, 10:50 PM | #4 |
The 65t should be set at 0 degrees As for wiring, I did mine like this. Is the battery new? Hope it helps! |
09-06-2006, 10:56 PM | #5 |
thanks fellas!!! im going to re-wire it in parallel tomarrow night while my wife packs up the truck and stuff... im also going to pick up 2 new batteries tomarrow after work. and if all that fails... im still comin to moab and i guess we will see if the BIG BRAINS can figure out whats wrong.
09-06-2006, 11:24 PM | #6 |
See.. thats why this site is soo popular! I removed the rear motor and ran it as if it only had 1 motor.. problem solved! tomarrow when i get home im going to change around the wiring and do the small stuff.
09-06-2006, 11:52 PM | #7 | |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
09-07-2006, 08:22 AM | #8 |
everythings good... gregrocks90046 had a good point to, everyone on this board is very helpful, if anything needed work prior to the comp, im sure everyone would be great.
09-07-2006, 08:25 AM | #9 | |
So for those of you hooking up a clod based crawler with 2 65T lathes...DO NOT WIRE THEM IN SERIES!!!! EVER! IT SUCKS!!! | |
09-07-2006, 09:13 AM | #10 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
See and here I was telling my wife "I know it is crazy, but I'm packing up my soldering iron and taking it with me". Now for sure I will take it. |
09-07-2006, 10:37 AM | #11 |
man im bringin everything!!! and i mean everything... i will have my shop in the back of the truck... im not going to moab to be all, snap, well that was fun. oh well time to go home... NACIH (not a chance in H...) Im comin to play!
09-07-2006, 08:22 PM | #12 |
just got done re-wiring everything and it works perfectly!!!! Moab!!!!
