02-28-2013, 07:57 AM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| My Kyosho run a dig? KYOSHOˇĂPRODUCT | Syncro KT-201 Set I am using this with my XR10. I am still learning about all the electronics. Will this 3rd channel switch operate a dig? I want to pull the trigger on a punk dig but I want to make sure this setup will run it. |
02-28-2013, 10:15 AM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: SWE
| Re: My Kyosho run a dig?
3rd-channel additional function <3-position switch / 0-120% offset for each position> functions compatible with all channels says the link. id say yes, if not mixing with dual esc exist. the 3d ch 3pos switch shoud work with punk. not 100% sure, no punk dig user |
02-28-2013, 12:21 PM | #3 |
Its funny. All my research, I think I got the idea of how to wire up the dig but not physically operate it. I suppose the switch goes up to engage the front, down to engage rear, middle.position for 4 wheel drive
My Kyosho run a dig? - Similar Threads | ||||
Kyosho Syncro KT-201 good for using dig? | Olle P | Team Losi Comp Crawler | 8 | 05-16-2012 11:06 AM |
Kyosho Rock Force dig plates. | Reflection | Axles, Trannys, T-case | 14 | 09-29-2011 02:29 PM |
kyosho dig unit | brian1981 | Kyosho Crawlers | 1 | 04-02-2010 11:29 AM |
Kyosho Rock Force Dig Fix | stampedeproject | Kyosho Crawlers | 13 | 06-23-2009 10:13 PM |
