03-03-2013, 03:41 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Willows
| tweeking out
Ok so this may be a stupid question but I have a savox servo, tekin fxr, integy 45t motor, sr300, futaba dig servo and 2s lipo. The whole setup is tweeking out when I turn either direction fully. I am NOT running a Bec, I don't have one and I thought I would be ok. Does anyone have any idea? Any help would be awesome. Thanks for looking.
03-03-2013, 03:54 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
| Re: tweeking out
You need a bec, savox servos pull lots of power.
03-03-2013, 04:52 PM | #3 |
| Re: tweeking out
While an external BEC won't hurt, check one thing first. See if the TX EPA's are set so the servo stops just before the steering binds. If the EPA's are not set correctly, you will kill the BEC or servo if you up the power.
03-03-2013, 05:06 PM | #4 |
| Re: tweeking out
I am running this same servo in my brothers venom creeper with no problem. And ok I will try to lessen the epa
03-03-2013, 06:10 PM | #5 |
RCC Addict Join Date: Jan 2010 Location: Dallas
| Re: tweeking out
Each setup can be different even when you try to mirror things. i say go bec. That way you can actually get more grunt out of your servo as I am guessing the rx or even the esc may have it at 4.7v.
03-03-2013, 09:56 PM | #6 |
| Re: tweeking out
I'm only running 1.9s and I think adjusting that helped out. If it still does it I will eventually invest in a Bec.
03-07-2013, 12:29 AM | #7 |
| Re: tweeking out
ok so my fxr doesnt like 3s lipos,and it gets warm. its fine on my 2s. what in the world is going on?
03-07-2013, 01:59 AM | #8 |
| Re: tweeking out
What is your gearing? My FXR doesn't even get warm with a 35t and 3s. And I'm another 1 for adding a BEC. Only $20 and a ton more power to the servo.
03-07-2013, 06:59 AM | #9 | |
| Re: tweeking out Quote:
You are likely either overgeared or have binding in the drivetrain. | |
03-07-2013, 07:42 AM | #10 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: tweeking out |
03-07-2013, 07:45 AM | #11 |
| Re: tweeking out
I am running a stock wraith spur with a 16t pinion.
03-07-2013, 07:47 AM | #12 |
| Re: tweeking out |
03-07-2013, 07:48 AM | #13 |
| Re: tweeking out
You may want to drop that down to a 13 or 14 tooth. If you are crawling you'll want the extra gearing. Most crawlers run 13-16/87. So you may be a bit under geared. Just slap a smaller pinion in there and give it a shot. Also like Charlie said, check for any binding. That will heat things up real quick.
03-07-2013, 08:53 AM | #14 |
| Re: tweeking out
I think my pinion/spur mesh its too tight. And I will solder a Bec in soon.
03-07-2013, 10:41 AM | #15 | |
The BEC built into the fxr does not like 3s. I run my fxr's on 4s into 30t handwounds pack after pack without heat issues. pull the red wire, add a BEC and the heat issues will go away. If it was a gearing or binding issue is would not go away with 2s. | |
03-07-2013, 12:57 PM | #16 |
| Re: tweeking out
Yeah true. I will put my Bec on when I get a chance to
