09-11-2006, 03:15 AM | #1 |
Rock Stacker Join Date: Jun 2005 Location: Australia
| EVX problems
Ok,I have bought a txt roller and i got it going tonight... but i have ran into a problem with the evx? Im running a mod evx to run 1 battery, 2 35t lathes in series,1400 intellect rx pack,tq3 radio and recivier and a hitec 5955 they all run off a 3300 battery When the truck is on it and i turn full lock left or right and then try to go forward or reverse nothing happens, but once i stop steering and let the wheels go back to centre and then hit forward or reverse it works fine, i set up the esc again, and still the same what could my problem be? do i need more voltage? any info would be great Tom. |
09-11-2006, 04:20 AM | #2 |
Pebble Pounder Join Date: May 2006 Location: fremont
turn servo setting down steering limiting on the servo
09-16-2006, 09:51 PM | #3 |
i hope u understood what i meant lol i cant remember what its called when i had it it did hte same thing turn it down a little and it will work fine and it doesnt limit the steering the robot servo i put in it before i sent it to u is insane, but its turning radius lock to lock is more then the txt's steering is so it draws more current and motors it just needs adjustment to find the sweet spot
