03-13-2013, 09:08 PM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: victorville
| xp esc brushless system can i run two battery
hi have xp sc1200-bl brushless esc and i have two 7.2 ni-mh 4500 mah i would like to now if i can put them together and do i put them positive to positive or positive to negative thanks
03-13-2013, 11:13 PM | #2 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
| Re: xp esc brushless system can i run two battery
depends. are you wanting to double run time or power?
03-14-2013, 06:09 AM | #3 |
Run time
03-14-2013, 05:20 PM | #4 |
Parallel, tie the 2 "+" together and the 2 "-" together. This adds the capacity (mah) but keeps the same voltage. I would make a "T" adaptor so the packs remain seperate, thus easier to swap out or charge. You can also run a single pack or 2 packs easily. |
03-14-2013, 05:40 PM | #5 |
+1 with what charlie said. depending on your connector, you can buy the parallel adapter that just plugs in. saving you a soldering headache..... |
03-14-2013, 10:29 PM | #6 |
Thank you guys
03-14-2013, 10:39 PM | #7 |
One more question with do double mah will it make it a 12 cell or stay 6 cell. They r both 6cell the esc max is 8 cell |
03-15-2013, 05:11 AM | #8 | |
| Re: xp esc brushless system can i run two battery Quote:
The proper description of what you want is a: 6S2P (6 cells in series, 2 packs in parallel). | |
03-15-2013, 06:10 AM | #9 |
Ok cool thanks
xp esc brushless system can i run two battery - Similar Threads | ||||
Traxxas Velineon Brushless Motor & ESC Power System | tallguy964 | Electronics | 8 | 06-18-2010 08:31 PM |
EZ RUN brushless system | rockcrawler150 | Electronics | 5 | 02-05-2010 02:58 PM |
