03-16-2013, 08:45 PM | #1 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Ae-2 need answer ASAP
My ae2 esc is connected to an Orion 19t method modified motor and it won't chime in the motor. I cleaned the com, but it still won't work. Then I tried to reconnect the RX to the TX but that didn't work either. Help please |
03-16-2013, 08:47 PM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: Ae-2 need answer ASAP
You say it doesn't "chime", but does it work?
03-16-2013, 08:52 PM | #3 |
It'll chime the first time to say its connected, but not the second time to say the motor is. And the motor won't go.
03-16-2013, 09:03 PM | #4 |
Have you tried a different motor?
03-16-2013, 09:10 PM | #5 |
No. Dont have one.
03-16-2013, 09:17 PM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Will the servo turn? Try to recalibrate the esc. If after recalibration it still doesn't run the motor then the motor is bad.
03-16-2013, 09:21 PM | #7 |
Rock Crawler Join Date: Nov 2010 Location: south prairie
I had this same problem last year with the same esc....the esc was bad. Servo would work, throttle wouldn't no matter what I did.
03-16-2013, 09:26 PM | #8 |
The same thing is happening to me. I hope it's not bad... Can't afford it right now...
03-16-2013, 09:29 PM | #9 |
Wait... How do I recalibrate it? |
03-16-2013, 09:30 PM | #10 |
| Re: Ae-2 need answer ASAP You can connect the motor directly to the battery to see if it will turn. Just be careful not to short anything. If the motor spins it isn't the problem. The LEDs can tell you what is going on with the ESC. Here is a link to the Castle Creations FAQ page. See #13 for decoding the LED Status. Castle Creations | FAQ: 1/10th Scale Products |
03-16-2013, 09:33 PM | #11 |
Turn on radio. Pull trigger and cut esc on. When it beeps, full reverse. When it beeps go to neutral, should beep again.
03-16-2013, 09:41 PM | #12 |
Thanks guys! It was the throttle trimm....
Ae-2 need answer ASAP - Similar Threads | ||||
can anyone answer this ???? | rc_pimp | Electronics | 4 | 05-06-2010 04:26 PM |
will this work need answer asap | rider12693 | Electronics | 6 | 09-16-2009 07:27 PM |
answer me this | toyota_yes_please | Chit Chat | 5 | 04-21-2006 03:08 PM |
